[GRASS-user] Fortran DOS programs and GRASS GIS
Hello All,
Best wishes from Greece.
A short question (I have no software development
experience, so please bare with me):
I am working with a 1-dimensional model:
which is written in Fortran
has available source code
runs on windows as a DOS program
provides output (plant growth, pollution etc) in one
dimension.
I would like to make a spatial, grid based use of it.
So, how could I:
Use the exisitng fortran code in Linux ( or the DOS
file)
Create a grid with the input values
run the program on a per-grid basis
have output written back to the database or grid
While searching on the GRASS GIS mailing lists, I have
seen some comments on using r.mapcalc for similar
situations.
Anyway, it would be a great halp if someone can
recomend a step by step method to develop this.
Thanks, Dimos
I would create a soft link between GRASS and your code, in the sense
that input can be generate by GRASS and exported in right format to feed
the model, then the output of the model will be imported by GRASS and
analyzed or visualized. To do this, you can use shell scripting
capabilities (or other scripting language, e.g. pyton, php,...).
In order to be able to give you a more specific answer, I should know a
couple of things...
- what input are needed to run your code? (ascii files?)
- what output are produced? (ascii files?)
Maxi
Dimos wrote:
Hello All,
I am working with a 1-dimensional model: which is written in Fortran
dimension.
So, how could I:
file)
situations.
Thanks, Dimos
grassuser mailing list
grassuser@grass.itc.it
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
