I am using grass6.4.2svn on an ubuntu laptop and I would like to use a different font - DejaVuSansMono-Bold.
I have tried: grass.run_command('d.text',flags='s' ,at='15,80',size='18', text='testings', path='/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono-Bold.ttf')
without errors, but no text.....
When I try: g.mkfontcap -o extradirs='/usr/share/fonts/truetype/ttf-dejavu/'
I get :
WARNING: This GRASS installation was compiled without Freetype support,
extradirs parameter ignored
When I compile I have: --with-freetype --with-freetype-includes=/usr/include/freetype2
And for me it seems to compile wtih Freetype support.
I have tried:
text='testings',
I get :
Freetype support,
extradirs parameter
ignored
What do I do wrong?
I don't have an exact answer to your question, but I would suggest to
run 'd.font -l' (or -L) and check if it is already there, then
in an Xmonitor try 'd.font DejaVuSansMono-Bold' before running
d.text (without path= or font=).
I don't think extrafont= is needed for that standard font dir, maybe try
g.mkfontcap without it?
Also [fwiw in my personal preference] the Vera font does a nicer job than
the almost-the-same DejaView, especially for numbers. I don't know why
Ubuntu dropped it but you can install the .deb from Debian and it all
works fine.
I get :
What do I do wrong?
First, ensure that you don't have multiple versions of GRASS. Second,
run "make clean" whenever you run the configure script.
