Rich Shepard wrote
I'm about to give up for today, but perhaps fresh eyes will see what I'm
not seeing.
Input data fragment:
name,lon,lat,elev,sampdate,prcp
Headworks Portland
Water,2370575.38427211,199337.634652112,228,2005-01-01,0.59
Six fields comma separated.
Command:
v.in.ascii in=$HOME/projects/data/precipitation/rainfall.csv skip=1
out=precip sep=comma columns='name varchar, lon double precision, lat
double
precision, elev double precision, sampdate varchar, prcp double precision'
x=2
y=3 z=4 --o
Six columns defined.
What grass reports:
Scanning input for column types...
Number of columns: 7
Number of rows: 113570
ERROR: 'x' column is not of number type
I just do not see where grass finds that seventh column that shifts 'x'
out of position. No name has a comma within it.
tested here with a simple copy/paste from your example
the content of input.txt
Headworks Portland
v.in.ascii input=D:\temp\atlas_druck\input.txt output=testinput
separator=comma skip=1 columns=name varchar, lon double precision, lat
double precision, elev double precision, sampdate varchar, prcp double
precision x=2 y=3 z=4
Number of columns: 6
Number of rows: 2
WARNING: Column number 4 <elev> defined as double has only integer values
Importing points...
Populating table...
Building topology for vector map <testinput@data>...
Registering primitives...
(Sat Aug 11 11:50:43 2018) Command finished (0 sec)
does rainfall.csv looks like your Input data fragment?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
