Dear Marcello,
You are right, for some reason, some of the code in the grass addons is not present anymore.
Probably, the evapotranspiration module has been moved in the trunk (i.evapo.pm, see http://grass.osgeo.org/grass70/manuals/i.evapo.pm.html)
Also the code for r.hydrofoss is missing (I don’t know why…). I will put on the server as soon as I will be back in the office.
By the way, If I correctly understand your goials, I don’t think that hydrofoss is suitable for your scope.
It is far away from being a simple and fast module to get a rough estimates of water availability regarding a basin.
Probably, some concentrate module, can be most suitable: using less parameters and being more tested.
The calibration, can be tricky and it has to be done in both the case, so you need a sufficient number of observations regarding river discharge in at least one point along the rivers (possible at basin closure point).
HEC-HMS could be one options (http://www.hec.usace.army.mil/software/hec-hms/index.html, http://www.hec.usace.army.mil/software/hec-hms/documentation/HEC-HMS_QuickStart_Guide_3.5.pdf)
I would suggest (if you can understand italian) to take a look at this http://www.hydro.unibo.it/teaching/IRI/slides/07_ModelliIdrologici.pdf to get a better idea of the different types of hydrological models and scopes of each of the existing types (see slide number 3).
Please, let me know if anything is needed. i will try to restore the old page related to HydroFoss in the REDME file.
Best regards,
Maxi
2012/12/15 Marcello Benigno <benigno.marcello@gmail.com>
Hi Markus,
I referred to the link that is inside the README (http://istgis.ist.supsi.ch:8001/geomatica/index.php?id=1).
Marcello Benigno B. de Barros Filho
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
