Dear all,
exporting a GRASS vector in Postgis suing v.out.ogr the geometry srid is not conserved and I obtain a table with srid = 900914.
There is a way to force the srid export of a grass vector using v.out.ogr?
Something like the “-a_srs” option of the ogr2ogr command.
Many thanks in advanced.
Roberto
Hi Roberto,
My experience is that it’s just best to export from GRASS as a shapefile and then import into PostGIS, specifying the coordinate system as I import. That’s for that very reason - otherwise the coordinate system seems not to make it out of GRASS, or perhaps it’s PostGIS that can’t read it, not sure.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee@isi-solutions.org
Web: http://www.isi-solutions.org
2012/5/14 Roberto Marzocchi <roberto.marzocchi@gmail.com>
Dear all,
Roberto
grass-user mailing list
grass-user@lists.osgeo.org
On Mon, May 14, 2012 at 4:52 PM, Daniel Lee <lee@isi-solutions.org> wrote:
My experience is that it's just best to export from GRASS as a shapefile and
That's for that very reason - otherwise the coordinate system seems not to
While I would not expect that/if so consider it to be a bug, could you try to
enable debug output?
g.gisenv set=DEBUG=3
The output may give ideas.
Use
g.gisenv set=DEBUG=0
to disable then debug output.
or perhaps it's PostGIS that can't read it, not sure.
Best,
Daniel
B.Sc. Daniel Lee
Softwarecenter 3
35037 Marburg
Dear all,
v.out.ogr?
Something like the "-a_srs" option of the ogr2ogr command.
Roberto
