We are working in a solar energy project to locate potential sites for solar panel farms. We are using the Landsat 7 panchromatic band to derive radiance with i.landsat.toar (W/m2srµm units). Now, we have access to some ground data from sensors measuring global horizontal irradiance (GHI) which output is in W/m2 units. I would like to compare these datasets for validation, so, my question is rather simple: ¿Is there a way to convert radiance in W/m2srµm to irradiance in W/m2?
I have read in [1] that radiance = irradiance / π, but I don’t completely understand, also, this doesn’t take the spectral part (µm) into account. I will very appreciate any further explanation about this… thank you very much in advance!!!
ANDRES OSWALDO CALDERON ROMERO
M.Sc. Geoinformation Sciences & Earth Observation
Grupo de Investigación Aplicada en Sistemas - GRiAS
Universidad de Nariño
Pasto - Colombia
T: (+57) 301 382 9659
Correo Electrónico - Universidad de Nariño
Pasto - Nariño - Colombia www.udenar.edu.co
It looks from the definition of GHI that solar farming needs r.sun
to answer to your question,
steradian (sr) is a “solid angle” of conic form, to which a circle applies for a plan projected footprint.
micro-meter (µm) is a spectrum value for the middle of the Landsat band used.
Yann
On Wed, Jun 17, 2015 at 10:18 PM Andrés Oswaldo Calderón Romero <aocalderon@udenar.edu.co> wrote:
Hello list,
Pasto - Colombia
