[GRASS-user] From pointcloud to dem - help
Dear Grass users,
I have a pointcloud form PMVS
(http://grail.cs.washington.edu/software/pmvs/) consisting of near to 6
million points.
The pointclouddata is georeferenced into world-coordinates (EUREF-89), and
stored in a text file with the following format: X Y Z R G B. (RGB colordata
can be deleted if required).
What I want to do is to import the pointcloud into Grass 7.0, and to
generate a surface modell/ dem, and to export the dem to a common
file-format, e.g. ESRI SHP or Land-XML.
I am quite new to Grass, so I would very much appreciate a brief description
of the steps I will need to go through in order to obtain this.
(Sorry for being so little specific about my question at this point).
Best regards,
Jorn
View this message in context: http://osgeo-org.1803224.n2.nabble.com/From-pointcloud-to-dem-help-tp5914470p5914470.html
On Wed, Jan 12, 2011 at 2:17 PM, Jorn Anke <jornanke@hotmail.com> wrote:
Dear Grass users,
million points.
First, import the point cloud with v.in.ascii. You can then filter the
points with the lidar tools to remove outliers (v.outlier) and obtain
a digital terrain model and a digital surface model
(v.lidar.edgedetection, v.lidar.growing, v.lidar.correction). The
v.surf.* modules can create a (raster) DEM by interpolating the
points. GRASS prefers raster maps for surface/terrain representation;
that also means that ESRI SHP or Land-XML being vector formats are not
really appropriate for a DEM. Common raster formats are e.g. GeoTIFF,
Erdas Imagine, or ESRI .hdr [1].
Markus M
[1] http://www.gdal.org/formats_list.html
Jorn Anke:
> consisting of near to 6 million points.
see http://grass.osgeo.org/wiki/LIDAR
specifically the Snake River micro-tutorial section about DEM
creation (but ignore the irrelevant LAS stuff there).
> (EUREF-89), and stored in a text file with the following
> Grass 7.0, and to generate a surface modell/ dem, and to
> export the dem to a common file-format, e.g. ESRI SHP or
> Land-XML.
unless you have a real need for it, I'd suggest to stick to the
stable GRASS 6.4 release.
In that case I'd strongly recommend you stay with a 6.4 release.
> obtain this.
that will choke for more than ~ 3 million points unless you start
without topology, or have several GB of RAM and a bit of time.
Importing without topology is a trick I'd reserve for users
already well familiar with the GIS, as lots of things don't work
right if topology is missing.
You can then filter the points with the lidar tools to remove
outliers (v.outlier) and obtain a digital terrain model and a
digital surface model (v.lidar.edgedetection, v.lidar.growing,
v.lidar.correction). The v.surf.* modules can create a
(raster) DEM by interpolating the points.
In this case advanced filtering doesn't seem necessary, so I'd
recommend import directly to raster with r.in.xyz, which can
handle an arbitrary number of input points (hundreds of billions
anyway). First read up on the "raster intro" quick start document
as a guide on how to set up your raster grid bounds and
resolution to suit ("region" in grass parlance).
regards,
Hamish
