[GRASS-user] From Vector to raster
Hello! i’m having problems in the simple task of convert a vector to a raster. I have obteined my vector polygon starting from 2d points in my map (v.hull) i can see the new polygon and now i want to create a raster with “1” values inside the area and null values outside. I used [v.to.rast] to do that, specifing as input feature type only area and as raster value (for use=val) “1”. Everything seems to work but when i question the map i find that both inside and outside my polygon instead than “0” and “1” i have “no values”
(must say that im a beginner). thanks a lot for the help!!
On 06/11/18 09:34, francesco sapienza wrote:
Hello! i'm having problems in the simple task of convert a vector to a raster. I have obteined my vector polygon starting from 2d points in my map (v.hull) i can see the new polygon and now i want to create a raster with "1" values inside the area and null values outside. I used [v.to.rast] to do that, specifing as input feature type only area and as raster value (for use=val) "1". Everything seems to work but when i question the map i find that both inside and outside my polygon instead than "0" and "1" i have "no values"
You probably have to set the computational region first. This determines the grid in which any new raster is written, both its extent and its resolution (see [1] for a bit more information).
Depending on the size of the area covered and the resolution desired, you can use something like this:
g.region vect=YourPolygon res=YourDesiredResolution [-a if you want to make sure to get precisely this resolution, and have the extents widened to fit to this resolution - see g.region manual page for details]
Then try v.to.rast.
Moritz
[1] https://grass.osgeo.org/grass74/manuals/rasterintro.html
