[GRASS-user] function doesn't work anymore
Hi this function
Hi this function:
def normalize (inras,outras):
min = grass.raster_info(inras)[‘min’]
max = grass.raster_info(inras)[‘max’]
grass.mapcalc(“$outras = float(($inras -$valuem) / ($valueM-$valuem))”, inras = inras, outras = outras, valuem = min,valueM = max, overwrite=True)
grass.run_command(‘g.remove’, flags=‘f’, type=‘raster’, name=inras, quiet=True)
doesn’t work anymore
apparently the syntax changed for min = grass.raster_info(inras)[‘min’]
could you help
thanks
Grazia
On 14/07/15 16:41, Gra wrote:
Hi this function
Hi this function:
min = grass.raster_info(inras)['min']
max = grass.raster_info(inras)['max']
grass.mapcalc("$outras = float(($inras -$valuem) / ($valueM-$valuem))",
grass.run_command('g.remove', flags='f', type='raster', name=inras,
quiet=True)
apparently the syntax changed for min = grass.raster_info(inras)['min']
Could you give us more details: version of GRASS GIS, error message, etc ?
Moritz
