[GRASS-user] FW: connecting to postgresql and postgis backend database - Grass 6.4.4svn
I’m having some problems with password authentication when trying to connect to postgresql.
Here is the generated error:
(Fri Mar 21 10:25:16 2014)
g.remove vect=building@PERMANENT
Removing vector building@PERMANENT
DBMI-Postgres driver error:
Cannot connect to Postgres: FATAL: password authentication
failed for user “pshapley”
WARNING: Unable to open database by driver
WARNING: Unable open database by driver
WARNING: Unable to find table <npt_planning.building> linked to vector map
WARNING: couldn’t be removed
WARNING: nothing removed
(Fri Mar 21 10:25:17 2014) Command finished (0 sec)
Is this problem linked with Ticket #1274 because if i use ‘v.in.ogr’ (with the -t) option
it imports all the geometries without the attributes (not much use)?. When the import is finished
I am asked to ‘try to rebuild topologies with v.build’ but this does not work.
Any ideas would be great.
Paul Shapley
