[GRASS-user] FW: r.lake issues
To: qgis-user@lists.osgeo.org
Subject: r.lake issues
Date: Tue, 28 Aug 2012 04:55:59 +0000
HI! ALL
I have been trying to generate a lake feature from dem and seed raster files using r.lake, this is information below.
The areas are not created as values can be seen below.
r.lake dem=e15234@user1 seed=seed@user1 wl=50 lake=seed50
Lake depth from 0.000000 to 0.000000
Lake area 0.000000 square meters
Lake volume 0.000000 cubic meters
Volume is correct only if lake depth (terrain raster map) is in meters
Successfully finished
What could be the reason.
AMBRISH DHAKA
THANKS! IN ADVANCE
Hello,
please check following things:
1) water level at seed point/area is above terrain (provided DEM);
2) seed point/area is located within current computational region
(just run g.region rast=my_dem before r.lake);
3) seed point/area has values > 0 (quirk of current implementation).
Good luck!
Maris.
PS. 3rd check probably could be eliminated by slight alteration of
r.lake code. Just a note to myself :wink:
2012/8/28 ambrish dhaka <ambijat@hotmail.com>:
HI! ALL
AMBRISH DHAKA
THANKS! IN ADVANCE
grass-user mailing list
grass-user@lists.osgeo.org
