[GRASS-user] FW: r.out.xyz: Output error
Hi Markus
Yes, I am executing it from the GUI, but I also tried it from the Command
Console and got the same result.
Not understanding why it isn't working. As I'd suspected, you have not made
any changes to this module.
Thanks
  Stephen
-----Original Message-----
From: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] On Behalf Of
Markus Neteler
Sent: 30 March 2013 18:09
To: Stephen Brearley
Cc: GRASS user list
Subject: Re: [GRASS-user] r.out.xyz: Output error
On Sat, Mar 30, 2013 at 6:41 PM, Stephen Brearley
<mail@stephenbrearley.name> wrote:
  r.out.xyz input=elev_ned_30m@PERMANENT
output=D:\_SDB\GIS_DataBase\Grass\_Demo\Demo_locations\nc_spm_08\PERMA
NENT\elev_ned_30m_xyz2
  'output' is not recognized as an internal or external command,
operable program or batch file.
To me it looks as if there is a linebreak before the output parameter. How
do you call r.out.xyz - in a scripts?
I believe this is a 'basic' feature that is unlikely to have been changed.
Right, the output parameter is the same
http://grass.osgeo.org/grass70/manuals/r.out.xyz.html
Changed parameters are listed here:
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Rastermodulechanges
Has it not been implemented yet, or should I be sticking with 6.4.2?
Please let us know how you execute above command.
Apparently not from the GUI.
