[GRASS-user] FW: Temporal + export
Hi everyone!
I never used a list… I think I made a mistake when sent the message yesterday…
I was construct a strds in grass 7.0.3, and I want to export it for use in R to do some statistics not included with tgrass… But when I do the export operation, I receive this message:
Usising the GUI:
t.rast.export --overwrite --verbose input=LST2@MOD11A2 output=C:\SIG\Base de datos area de estudio\Datasets_R\LSR_R compression=gzip
File “C:\OSGEO4~1\apps\grass\grass-7.0.3/scripts/t.rast.ex
port.py”, line 87, in
main()
port.py”, line 82, in main
_input, output, compression, directory, where, _format,
“strds”)
File “C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass
temporal\stds_export.py”, line 268, in export_stds
new_cwd = tempfile.mkdtemp(dir=directory)
File “C:\OSGEO4~1\apps\Python27\lib\tempfile.py”, line
329, in mkdtemp
_os.mkdir(file, 0700)
WindowsError: [Error 3] El sistema no puede encontrar la
ruta especificada: ‘/tmp\tmppi2oh1’
(Wed May 04 16:09:44 2016) Comando finalizado. (1 segundos)
In python (very difficult):
input=“LST2@MOD11A2”
output=“LST_R.tar.gz”
compression=“gzip”
directory=“C:/SIG/Base de datos area de estudio/Datasets_R/”
where=None
format_=“GTiff”
type_=“strds”
tgis.export_stds(input, output, compression, directory, where, format_, type_)
File “”, line 1, in
File “C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\temporal\stds_export.py”, line 298, in export_stds
rows, tar, list_file, new_cwd, fs, format_)
File “C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\temporal\stds_export.py”, line 74, in _export_raster_maps_as_gdal
nodata = max_val + 1
TypeError: unsupported operand type(s) for +: ‘NoneType’ and ‘int’
Some idea? I was try to set the nodata values to 0 using gdalwarp but this doesn’t work apparently…
Thanks you!!
Matías
Hi Matías,
On Thu, May 5, 2016 at 5:41 PM, Matías Alejandro Castillo Moine
<matialecastillo@hotmail.com> wrote:
Hi everyone!
I never used a list... I think I made a mistake when sent the message
yesterday...
now it reached the list :slight_smile:
(Would it be possible for you to update to 7.0.4? Just to be sure that
the problem is yes/no solved?
to do some statistics not included with tgrass.. But when I do the export
Usising the GUI:
Hint: You are using white space in the path ("Base de datos area de
estudio\"). Maybe it doesn't matter but just to exclude this potential
issue, please try with a different path name.
  File "C:\OSGEO4~1\apps\Python27\lib\tempfile.py", line
329, in mkdtemp
ruta especificada: '/tmp\\tmppi2oh1'
This looks like a bug: it uses /tmp/ which does not exist on Windows.
The current code is:
/lib/python/temporal/stds_export.py, line 274
    # Create the temporary directory and jump into it
    os.chdir(new_cwd)
but AFAIK it should use this portable function:
lib/python/script/core.py:def tempdir():
@devs: opinions?
Concerning the other issue:
input="LST2@MOD11A2"
output="LST_R.tar.gz"
compression="gzip"
directory="C:/SIG/Base de datos area de estudio/Datasets_R/"
where=None
format_="GTiff"
type_="strds"
type_)
  File "<input>", line 1, in <module>
  File
"C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\temporal\stds_export.py",
  File
TypeError: unsupported operand type(s) for +: 'NoneType' and 'int'
...here I have no suggestion. Anyone?
Hola Mati!!!
I’m so glad you are using grass and writing to the list! :slight_smile:
Markus won me, but I had the same pieces of advice.
First idea/advice: do not use folder names (nor file names) with spaces, second: maybe you wanna update to 7.0.4, the new stable release.
I’ve tried here (grass71, fedora23 box) with:
t.rast.export input=cla@clorofila output=cla.gzip compression=gzip directory=/home/veroandreo where=“start_time >= ‘2013-01-01’”
Checking GDAL data type and nodata value…
100%
Using GDAL data type
Input raster map contains cells with NULL-value (no-data). The value -nan
will be used to represent no-data values in the input map. You can specify
a nodata value with the nodata option.
Exporting raster data to GTiff format…
100%
r.out.gdal complete. File <A20130012013008.L3m_8D_CHL_chlor_a_4km_arg.tif>
created.
tar xvf cla.gzip
all is there and looks fine…
The nodata option comes from r.out.gdal [1]. t.rast.export uses it to export maps in the strds. Don’t know about gdalwarp, but in any case, if you will then import data into R for other analyses, you can change the value there.
Un abrazo,
Vero
[1] https://grass.osgeo.org/grass70/manuals/r.out.gdal.html
2016-05-05 12:41 GMT-03:00 Matías Alejandro Castillo Moine <matialecastillo@hotmail.com>:
Hi everyone!
Usising the GUI:
main()
“strds”)
329, in mkdtemp
compression=“gzip”
where=None
format_=“GTiff”
type_=“strds”
File “”, line 1, in
Thanks you!!
Matías
grass-user mailing list
grass-user@lists.osgeo.org
Hola Verooooo!
Thanks you for answer!
I’m working to solve it. Apparently all my imported rasters are zero cell values. There is something wrong with my gdalwarp command… I’ll tell you later…
Thanks!!!
Date: Thu, 5 May 2016 14:07:56 -0300
Subject: Re: [GRASS-user] FW: Temporal + export
To: matialecastillo@hotmail.com
CC: grass-user@lists.osgeo.org
Hola Mati!!!
100%
100%
created.
tar xvf cla.gzip
Un abrazo,
Vero
Hi everyone!
Usising the GUI:
main()
“strds”)
329, in mkdtemp
compression=“gzip”
where=None
format_=“GTiff”
type_=“strds”
File “”, line 1, in
Thanks you!!
Matías
Hola Mati!
Maybe if you tell us more about your data, workflow and the commands you are using, we could help you. What do you use gdalwarp for?
Vero
2016-05-06 18:24 GMT-03:00 Matías Alejandro Castillo Moine <matialecastillo@hotmail.com>:
Hola Verooooo!
Thanks!!!
Hola Mati!!!
100%
100%
created.
tar xvf cla.gzip
Un abrazo,
Vero
Hi everyone!
Usising the GUI:
main()
“strds”)
329, in mkdtemp
compression=“gzip”
where=None
format_=“GTiff”
type_=“strds”
File “”, line 1, in
Thanks you!!
Matías
On May 6, 2016 11:24 PM, “Matías Alejandro Castillo Moine” <matialecastillo@hotmail.com> wrote:
Hola Verooooo!
… maybe the data are there but the computational region wrong?
Hi! I´m again!
The problem whith galwarp is solved (spatial reference system was wrong).
But now, I have my time serie registered in Grass and when I export it, I can only export this using the AAgrid or pack format, and R needs the GTiff formatt into the tar.gz archive. I believe that I´m using correctly the command
t.rast.export --overwrite input=LST2@MOD11A2 output=MOD11A2.tar.gz directory=C:\SIG\Grass compression=gzip
WARNING: El tipo de datos GDAL seleccionado no cubre el rango de datos
WARNING: Tipo de datos GDAL: Byte, rango: 0 - 255
WARNING: Rango a exportar: 14837 - 15732
ERROR: La exportación raster puede resultar en una pérdida completa de datos, cancelando.
File “C:\OSGEO4~1\apps\grass\grass-7.0.4/scripts/t.rast.ex
main()
_input, output, compression, directory, where, format,
“strds”)
File “C:\OSGEO4~1\apps\grass\grass-7.0.4\etc\python\grass
temporal\stds_export.py”, line 97, in
shutil.rmtree(new_cwd)
File “C:\OSGEO4~1\apps\Python27\lib\shutil.py”, line 252,
in rmtree
onerror(os.remove, fullname, sys.exc_info())
File “C:\OSGEO4~1\apps\Python27\lib\shutil.py”, line 250,
in rmtree
os.remove(fullname)
WindowsError: [Error 32] El proceso no tiene acceso al
archivo porque está siendo utilizado por otro proceso:
‘C:\SIG\Grass\tmp883adw\archive’
(Fri May 13 13:09:21 2016) Comando finalizado. (2 segundos)
(Fri May 13 13:14:02 2016)
Some new idea?
Thanks!!!
Date: Sat, 7 May 2016 14:09:33 +0200
CC: veroandreo@gmail.com; grass-user@lists.osgeo.org
Hola Verooooo!
Hey, Mati! Hola!
(Hint: you may want to set language to English so more people can understand the error messages and help)
El may 13, 2016 1:17 PM, “Matías Alejandro Castillo Moine” <matialecastillo@hotmail.com> escribió:
Hi! I´m again!
If this is the command, you are not setting format there, so by default you should be exporting GTiff.
In the manual page for 7.1 also says that if you use gzip compression, you should add .tar.gzip to the output file name. This latter is not specified in 70 manual but I guess it applies here, too [0].
What I can see there is that you are exporting your maps as byte (0-255) when your data is not in that range (WARNING: Rango a exportar: 14837 - 15732). In t.rast.export for grasss 7.1 there’s a new parameter called type which allows to set data type and would allow you to change that [1]. Dunno which is default type for AAgrid or pack (not mentioned in the manual page), but for GTiff you have several options available (in that case you could try forcing type to UInt16, which would cover your data range). Anyway, this seems odd since you are using 7.0.4 and not 7.1, right?
@Luca, might the error and/or message be related to [2]?
main()
“strds”)
in rmtree
in rmtree
os.remove(fullname)
Some new idea?
Thanks!!!
Does r.out.gdal for only one map works? Something like
r.out.gdal input=LST output=LST.tif format=GTiff type=UInt16
Let us know :slight_smile:
Vero
[0] https://trac.osgeo.org/grass/ticket/2416
[1] https://grass.osgeo.org/grass71/manuals/t.rast.export.html
[2] https://trac.osgeo.org/grass/changeset/67961
On 13 May 2016 at 20:07, Veronica Andreo <veroandreo@gmail.com> wrote:
Hey, Mati! Hola!
Hi Vero, Matias
I don't think so
datos, cancelando.
  File "C:\OSGEO4~1\apps\grass\grass-7.0.4/scripts/t.rast.ex
port.py", line 87, in <module>
    main()
port.py", line 82, in main
"strds")
  File "C:\OSGEO4~1\apps\grass\grass-7.0.4\etc\python\grass\
temporal\stds_export.py", line 298, in export_stds
temporal\stds_export.py", line 97, in
  File "C:\OSGEO4~1\apps\Python27\lib\shutil.py", line 252,
in rmtree
  File "C:\OSGEO4~1\apps\Python27\lib\shutil.py", line 250,
in rmtree
    os.remove(fullname)
'C:\\SIG\\Grass\\tmp883adw\\archive'
it seems related to r.out.gdal, Matias could you try again the command?
Some new idea?
Thanks!!!
Matias is this working for you?
Vero
ciao
Luca
www.lucadelu.org
Hi everyone!
I solved this generating a .tif file with the target SRC, and then reading their SCR from .tif file when the grass location is created. Then I import all the .tif files (-o flag is not activated) and finally t.rast.export works correctly.
Thanks you!!!
Date: Thu, 9 Jun 2016 15:19:20 +0200
To: veroandreo@gmail.com
CC: matialecastillo@hotmail.com; grass-user@lists.osgeo.org
On 13 May 2016 at 20:07, Veronica Andreo veroandreo@gmail.com wrote:
Hey, Mati! Hola!
Hi Vero, Matias
I don’t think so
datos, cancelando.
main()
“strds”)
in rmtree
in rmtree
os.remove(fullname)
Some new idea?
Thanks!!!
Vero
ciao
Luca
www.lucadelu.org
