Just got 6.5svn compiled in Ubuntu 9.04 and I'm now trying to install
r.stream.order using g.extension. When I give the command
g.extension extension=r.stream.order prefix=${GISBASE}
I get:
[: 196: /home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu:
unexpected operator
[: 219: add: unexpected operator
And then the files are checked out from svn but compilation fails with
the messages bellow. Any hints? Do I need to checkout other extensions
first?
Thanks
Daniel
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
A r.stream.order/orders.png
A r.stream.order/main.c
A r.stream.order/description.html
A r.stream.order/global.h
A r.stream.order/io.c
A r.stream.order/order.c
A r.stream.order/Makefile
Checked out revision 43156.
Compiling <r.stream.order>...
/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include/Make/Module.make:25:
warning: overriding commands for target `install'
/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include/Make/Rules.make:90:
warning: ignoring old commands for target `install'
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include
-g -Wall -Werror-implicit-function-declaration -fno-common
-I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\"
-I/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/io.o -c io.c
io.c: In function ‘create_base_maps’:
io.c:57: warning: format not a string literal and no format arguments
io.c: In function ‘write_maps’:
io.c:172: warning: format not a string literal and no format arguments
OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:142: warning: format not a string literal and no format arguments
OBJ.i686-pc-linux-gnu/order.o -c order.c
order.c: In function ‘trib_nums’:
order.c:24: warning: format not a string literal and no format arguments
order.c:26: warning: format not a string literal and no format arguments
order.c: In function ‘find_nodes’:
order.c:68: warning: format not a string literal and no format arguments
order.c:97: warning: format not a string literal and no format arguments
order.c:108: warning: format not a string literal and no format arguments
order.c:123: warning: format not a string literal and no format arguments
order.c: In function ‘do_cum_length’:
order.c:164: warning: format not a string literal and no format arguments
order.c: In function ‘strahler’:
order.c:259: warning: format not a string literal and no format arguments
order.c: In function ‘shreeve’:
order.c:313: warning: format not a string literal and no format arguments
order.c: In function ‘horton’:
order.c:364: warning: format not a string literal and no format arguments
order.c: In function ‘hack’:
order.c:447: warning: format not a string literal and no format arguments
gcc -L/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/lib
-Wl,--no-undefined -Wl,--export-dynamic
-Wl,-rpath-link,/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/lib
-L/usr/lib -o
/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/bin/r.stream.order
OBJ.i686-pc-linux-gnu/io.o OBJ.i686-pc-linux-gnu/main.o
OBJ.i686-pc-linux-gnu/order.o -lgrass_vect -lgrass_dbmibase
-lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis
-lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis
-lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime
-lz -lgrass_linkm -lgrass_rtree -lgrass_dig2 -lgrass_gis
-lgrass_datetime -lz -lgrass_rtree -lgrass_dgl -lgrass_rtree
-lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -L/usr/lib
-lgdal1.7.0 -L/usr/lib -lgeos -lgeos_c -lgrass_dbmiclient
-lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lm
-lz
OBJ.i686-pc-linux-gnu/main.o: In function `main':
/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/main.c:54:
multiple definition of `springs'
OBJ.i686-pc-linux-gnu/io.o:/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/io.c:5:
first defined here
multiple definition of `outlets'
first defined here
/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/main.c:55:
multiple definition of `springs_num'
first defined here
multiple definition of `outlets_num'
OBJ.i686-pc-linux-gnu/io.o:/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/io.c:6:
first defined here
multiple definition of `stream_num'
OBJ.i686-pc-linux-gnu/io.o:/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/io.c:10:
first defined here
OBJ.i686-pc-linux-gnu/order.o: In function `trib_nums':
/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/order.c:7:
first defined here
first defined here
/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/order.c:8:
first defined here
first defined here
first defined here
collect2: ld returned 1 exit status
make: *** [/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/bin/r.stream.order]
Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
GRASS 6.5.svn (br_wgs84):~ >
