On Fri, Jan 31, 2014 at 3:56 PM, Craig Aumann <craigaumann@gmail.com> wrote:
Ok - so to work around the problem I compiled GRASS 70 with the following
flags following the instructions at
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
Not seeing any compilation errors.
CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
--enable-largefile=yes \
--enable-64bit \
--with-libs=/usr/lib \
--with-nls \
--with-cxx \
--with-proj-share=/usr/share/proj \
--with-geos=/usr/bin/geos-config \
--with-readline \
--with-python=yes \
--with-wxwidgets \
--with-cairo \
--with-opengl-libs=/usr/include/GL \
--with-motif \
--with-tcltk-includes="/usr/include/tcl8.5" \
--with-ffmpeg=yes --with-ffmpeg-includes="/usr/include/libavcodec
/usr/include/libavformat /usr/include/libswscale /usr/include/libavutil" \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-postgres=no \
--with-postgresql=no \
--with-sqlite=yes \
--with-mysql=no \
--with-odbc=no
When I start grass 70 I get:
Hit RETURN to continue
Starting GRASS GIS...
access: No such file or directory
ERROR: LOCATION </home/caumann/<UNKNOWN>> not available
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py", line 48, in
<module>
from gui_core.dialogs import TextEntryDialog
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/dialogs.py",
line 49, in <module>
from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/gselect.py",
line 59, in <module>
import grass.temporal as tgis
File "/usr/local/grass-7.0.svn/etc/python/grass/temporal/__init__.py",
line 29, in <module>
from temporal_vector_algebra import *
File
"/usr/local/grass-7.0.svn/etc/python/grass/temporal/temporal_vector_algebra.py",
line 436, in <module>
m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
File
"/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/module.py",
line 252, in __init__
tree = fromstring(self.xml)
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1302, in XML
return parser.close()
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
self._raiseerror(v)
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
_raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
Hit RETURN to continue...
^CTraceback (most recent call last):
File "/usr/local/bin/grass70", line 1324, in <module>
set_data()
File "/usr/local/bin/grass70", line 679, in set_data
gui_startup()
File "/usr/local/bin/grass70", line 700, in gui_startup
sys.stdin.readline()
KeyboardInterrupt
What did I forget to include???
You did everything right and you discovered another bug. I unfortunately
cannot reproduce it (Ubuntu 12.04).
Try please GRASS revision 58806:
svn up -r58806
make distclean
./configure...
make
./bin.../grass70
and if it will work (and you will have still strength to continue) please
try also revision 58807.
grass-user mailing list
grass-user@lists.osgeo.org
