[GRASS-user] g.gui.animation
I am sending this to user mailing list since I would like to let others know that this issue is resolved.
On Tue, Oct 1, 2013 at 1:12 PM, E.J. Neafsey <eneafse@lumc.edu> wrote:
Dear Anna,
Problem with g.gui.animate solved! It’s a long story, but I had several
versions of libpng on my system, and the most recent one (libpng16) was
loading into GRASS along with the others and messing things up. I moved
the library where it could not be found, recompiled GRASS, and
everything worked!
Thanks for your assistance. Your email said g.gui.animate worked on your linux
system and that made me start to suspect something on my system outside
of GRASS could be at fault.
Glad to hear that! If you have other issues, just ask.
Anna
Thanks again.
E.J. Neafsey
Anna Petrášová <kratochanna@gmail.com> writes:
are you using wxGUI (Layer manager + map display) or d.mon wx0? If you are
using d.mon, it could cause this strange behavior. If that’s not your case,
please try again with updated version of grass, I added some warning if
rendering fails. So have a look in the terminal if there is some warning.
You can also set debug mode before launching animation tool:
g.gisenv set=WX_DEBUG=5
g.gisenv set=DEBUG=5
and send me the output.
Hopefully some of these suggestions will be helpful.
Anna
On Mon, Sep 30, 2013 at 6:26 PM, E.J. Neafsey <eneafse@lumc.edu> wrote:
Dear Anna,
Thanks for your reply. I set the “computational region” to one of my
rasters but still could not get the actual rasters to display on the
screen.
The filename of the first raster is present at the upper left corner, but
no actual
picture appears. In addition, the filename does NOT change as the
slider moves across.
In addition, if I check the “Show raster legend” box in the “Add new
animation” window, , I receive the following error message, which may
help:
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/animation/
frame.py”, line 156, in OnAddAnimation
self.controller.AddAnimation()
controller.py”, line 256, in AddAnimation
self._setAnimations()
controller.py”, line 312, in _setAnimations
self._updateBitmapData()
controller.py”, line 371, in _updateBitmapData
self._loadLegend(animData)
controller.py”, line 403, in _loadLegend
bitmap = prov.LoadOverlay(animationData.legendCmd)
mapwindow.py”, line 503, in LoadOverlay
return wx.BitmapFromImage(autoCropImageFromFile(filename))
File
“/usr/local/grass-7.0.svn/etc/gui/wxpython/core/utils.py”,
line 1104, in autoCropImageFromFile
pilImage = Image.open(filename)
File “/usr/local/lib/python2.7/site-
packages/PIL/Image.py”, line 2006, in open
raise DecodeError(“cannot identify image file”)
DecodeError
Thanks for your help.
I wasn’t sure if I should reply to the list, so I sent this directly to
you.
E.J. Neafsey / eneafse@lumc.edu
My YouTube Channel:
http://www.youtube.com/channel/UCwCu_G_7KpSpSp48MHvyOYg?feature=mhee
My YouTube Channel:
