I had to quit the GUI Composer to check elevation units on the base raster
map since I have no access to the command line when g.gui.psmap is active.
When I re-invoked g.gui.psmap and loaded the saved specification file I
discovered that the legend, scale bar, and north arrow were moved from the
saved position and that a frame had been inserted when it was removed from
the saved file.
Have I done something incorrectly reloading the saved map specifications?
Rich
P.S. I can provide the .psmap file if that helps.
Rich
raster map since I have no access to the command line when g.gui.psmap is
active. When I re-invoked g.gui.psmap and loaded the saved specification
file I discovered that the legend, scale bar, and north arrow were moved
from the saved position and that a frame had been inserted when it was
removed from the saved file.
Never mind. Rather than fighting this I used ps.map. It worked once, now
tells me it cannot find the input file:
GRASS 7.5.svn:~/data/grassdata/> ls
/home/rshepard/projects/oregon/<project>/analyses/dubois_crk.psmap
GRASS sees it. So why doesn't ps.map see it?
GRASS 7.5.svn:~/data/grassdata/> ps.map
in=$HOME/projects/oregon/<project>/analyses/dubois_crk.psmap
out=$HOME/projects/oregon/<project>/analyses/dubois-creek.pdf ERROR: Unable to open file
'/home/rshepard/projects/oregon/estacada/analyses/dubois_crk.psmap':
No such file or directory
Grrr!
Rich
Fixed this by exiting grass and re-starting it.
Rich
