It appears that the only maps available for setting a ps.map region in the
cartographic composer are those of the current mapset. When looking at the
choices, no other mapset can be opened to view the contained maps. Is this
correct?
If so, I'll be sure to change the current mapset to the one with the
region I want to use for the cartographic layout.
TIA,
Rich
On Tue, Aug 14, 2018 at 6:50 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
correct?
no, you should be able to add maps from any accessible mapset, use g.mapsets -s to check your mapsets are accessible.
If so, I’ll be sure to change the current mapset to the one with the
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Anna,
In the ps.map manual I read setting the region using g.mapsets, but within
the cartographic composer the region setting dropdown choice box did not let
me select a map in a different mapset. Using g.mapsets -s is still on the
command line, not within the GUI as far as I can tell.
Best regards,
Rich
On Tue, Aug 14, 2018 at 9:36 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Anna,
It works for me, are we talking about “Map frame settings”?
not sure what you mean, g.mapsets -s sets the visibility of mapsets globally
Best regards,
Rich
within the cartographic composer the region setting dropdown choice box
did not let me select a map in a different mapset.
It works for me, are we talking about "Map frame settings"?
Anna,
Well, it seems to work here now, too.
Rich
