[GRASS-user] g.gui.tplot opens plot when exporting csv from cli
I’m trying to export in a csv the data used to plot a time series in a given point, and I have to run it in a script passing a series of coordinates, so the problem is that using g.gui.tplot from command line, it opens the plot and needs to be closed manually. Perhaps there is another tool more suitable for this purpose?
Thank you in advance
Margherita Di Leo
you might try to add the following line in before the call of g.gui.tplot in your script:
setenv DISPLAY /dev/null
This sends the gui to nowhere and is not visible and destroyed imediately hence.
regards
Stefan
Margherita Di Leo <diregola@gmail.com> hat am 12. Oktober 2018 um 10:39 geschrieben:
I'm trying to export in a csv the data used to plot a time series in a
Margherita Di Leo
grass-user mailing list
grass-user@lists.osgeo.org
Hi Margherita,
Try t.rast.what:
https://grass.osgeo.org/grass76/manuals/t.rast.what.html
Stefan
Margherita Di Leo
