[GRASS-user] g.list rast not working on wingrass.
Dear all,
I am running native wingrass, and every works fine since I installed
the GRASS. Yesterday I left running a r.cross and r.stats commands
on a large raster (60,000x48,000 cells) and got the wanted results.
But I don´t know why now I can´t run “g.list rast” on my system.
All comands works fine, but when I try to run “g.list rast” I get an
error windows (from native windows, something like “illegal call etc”),
and the GRASS return an empty list. But the GRASS don´t crach,
and I can continue running other commands without problem.
Only g.list that is not working.
Case you can give me some advice, I will be very grateful.
miltinho astronauta
brazil
Milton Cezar Ribeiro pisze:
I don´t know why now I can´t run "g.list rast" on my system.
All comands works fine, but when I try to run "g.list rast" I get an
error windows (from native windows, something like "illegal call etc"),
What GRASS version exactly (best give a link to where you dowloaded it
from)?
What Windows version?
Does 'g.list rast' fail in GUI or command line? Does e.g. 'g.list vect'
work?
Please post the *exact* error message too.
Maciek
Maciej Sieczka
www.sieczka.org
Dear Maciej,
Thanks for your reply.
I am running wingrass version 6.3.0 on a XP (service pack 2) and I donwload it from the official site grass.itc.it.
The “g.list rast” fail both on GUI and on command line.
But “g.list vect” works fine.
The error message is not on the “GUI” or Command Line, because it open a windows dialog with the message “An error was found and the program will be closed”, and when I see the error report I get something like “Error signature: AppName: g.list.exe AppVer: 0.0.0.0 ModName: libgrass_gis.6.3.0.dll ModVer: 0.0.0.0 Offset: 0001717e”.
In fact, it appears to be a “problem” on this Mapset only, because if I change the Location/Mapset I can run “g.list rast” without problem. Just to you know, I left my computer running large processing over two nigths (all process were done ok, without error message, and the results looks very fine) as I am working in a very large database (several 60,000x48,000 maps).
Thanks again for your time.
Kind regards
miltinho astronauta
brazil
2008/8/14, Maciej Sieczka tutey@o2.pl:
from)?
Does ‘g.list rast’ fail in GUI or command line? Does e.g. ‘g.list vect’
work?
Please post the exact error message too.
Maciek
Maciej Sieczka
www.sieczka.org
The "g.list rast" fail both on GUI and on command line.
But "g.list vect" works fine.
The error message is not on the "GUI" or Command Line, because it open a
windows dialog with the message "An error was found and the program will be
closed", and when I see the error report I get something like "Error
libgrass_gis.6.3.0.dll ModVer: 0.0.0.0 Offset: 0001717e".
In fact, it appears to be a "problem" on this Mapset only, because if I
change the Location/Mapset I can run "g.list rast" without problem.
Can you provide a recursive listing of the location directory?
From within an MSys shell, use e.g.:
  find /path/to/location -type f > list.txt
[Replace /path/to/location with the actual path to the location
directory; this needs to use MSys' syntax, e.g. /c/grass-data, rather
than Windows' syntax, e.g. c:\grass-data.]
