[GRASS-user] g.mapset unable to read GIS_LOCK env variable
Using Grass 6.4.0 from Osgeo4W in WinXP. When I try to change my
mapset inside a grass section by typing, for example, g.mapset
PERMANENT at the prompt I get the error:
GRASS 6.4.0svn (utm23)> g.mapset PERMANENT
ERROR: Unable to read GIS_LOCK environment variable
I get the same if I try to change the mapset using the wxgui. A WinXP
problem I guess?
Daniel
It's a known issue, although I'm surprised that it hasn't been fixed
already.
Setting GIS_LOCK (to anything) in init.bat should prevent the error.
Hi everybody,
I'm using GRASS 6.4.0 RC6 GUI=wxpython in WINdows XP.
When I try to change the current mapset (with g.mapset) inside a GRASS
session, I get the follow error:
"ERROR: Unable to read GIS_LOCK environment variable".
Gynn wrote: "Setting GIS_LOCK (to anything) in init.bat should prevent the
error", but I don't know how to do that: I'm a beginner GRASS user.
Can anyone help me?
Thanks a lot.
Antonello
View this message in context: http://osgeo-org.1803224.n2.nabble.com/g-mapset-unable-to-read-GIS-LOCK-env-variable-tp3121705p4955679.html
