[GRASS-user] g.mlist: order of numbers
hello,
I have a script which creates so far n rasters with an analysis on different
spatial scales.
Now I want to apply r.series for an analysis of their trend but doing it fails
because I haven't figured out, how to add all new images (name.1, name.2,
name.3,...., up to name.n ) to a r.series command in the correct order.
Theoreticall I can merge r.series and g.mlist as shown in the help pages but
when I run g.mlist the order is: name.1, name.11, name.12,....
It would be no problem adding $GIS_OPT_output.1, $GIS_OPT_output.2, ... by
hand, but because the number of scales differ I had to adept it every time
again.
any hint is appreciated, TIA, Martin
Martin Wegmann wrote on 07/23/2007 11:57 AM:
hello,
spatial scales.
again.
Martin
probably you have to fill with 0 to get the numbers right, using
something like
echo "1" | awk '{printf "%03d\n", $1}'
001
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
> hello,
> different spatial scales.
> fails because I haven't figured out, how to add all new images (name.1,
> name.2, name.3,...., up to name.n ) to a r.series command in the correct
> order.
> but when I run g.mlist the order is: name.1, name.11, name.12,....
> by hand, but because the number of scales differ I had to adept it every
> time again.
Martin
something like
001
I added .00 to the numbers but unfortunately that did not work, I get:
g.mlist type=rast pattern=$GIS_OPT_output*
test.001
test.0010
test.002
test.003
test.004
test.005
test.006
test.007
test.008
test.009
Martin
grassuser mailing list
grassuser@grass.itc.it
> > hello,
> > it fails because I haven't figured out, how to add all new images
> > (name.1, name.2, name.3,...., up to name.n ) to a r.series command in
> > the correct order.
> > pages but when I run g.mlist the order is: name.1, name.11,
> > name.12,....
> > every time again.
> Martin
> something like
> 001
test.001
test.0010
test.002
test.003
test.004
test.005
test.006
test.007
test.008
test.009
ah, sorry, just realized that I have:
test.0010
instead of
test.010
renaming test.0010 to .010 gives the correct order.
but I did not manage to get your example running, Markus.
my test.001 is "$1$, isn't it? So I have to replace $1 with my filename?
sorry, not a lot of experiences with awk.
Martin
Martin
> Markus
this is really *ugly* hack,
g.mlist rast pat=name*
name.1
name.11
name.110
name.2
g.mlist rast pat=name* | awk -F. '{print $2,$1}' | sort -n | awk
'{printf $2"."$1","}'
name.1,name.2,name.11,name.110,
r.series in=`g.mlist rast pat=name* | awk -F. '{print $2,$1}' | sort
-n | awk '{printf $2"."$1","}'` out=series method=average
would be better to write script for renaming maps
name.1 -> name.001, etc.
Martin
2007/7/23, Martin Wegmann <wegmann@biozentrum.uni-wuerzburg.de>:
> > hello,
> > order.
> > time again.
> Martin
> something like
> 001
test.001
test.0010
test.002
test.003
test.004
test.005
test.006
test.007
test.008
test.009
Martin
> Markus
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
> > > on different spatial scales.
> > > doing it fails because I haven't figured out, how to add all new
> > > images (name.1, name.2, name.3,...., up to name.n ) to a
> > > help pages but when I run g.mlist the order is: name.1, name.11,
> > > name.12,....
> > > $GIS_OPT_output.2, ... by hand, but because the number of scales
> > > differ I had to adept it every time again.
Markus:
> > something like
> > 001
see this post from last week for exactly that:
  http://grass.itc.it/pipermail/grassuser/2007-July/040423.html
Hamish
works fine even when having
test.001, test.002, ...., test.0010
or
test.1, test.2, ...., test.10
thanks, Martin
BTW would it be possible to add such a sorting method to g.mlist natively? Or
adding it the g.mlist/r.series man-pages?
