I'd like to list (using g.list) all raster maps
that start with rast_* but not those which start with
rast_A_* OR rast_B_* OR rast_C_*. I tried to use the
OR operator and | but without success so far.
Are such logical operators generally applicable with g.mlist?
On Tue, Feb 14, 2012 at 3:28 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
Probably yes. I suppose that you need to enable one of these:
-r
Use basic regular expressions instead of wildcards
-e
Use extended regular expressions instead of wildcards
g.mlist?
yes, the the basic or extended regex flags you can do pretty much any
pattern matching you can think of.
try like rast_[^A-C][^_]
see http://www.regular-expressions.info/
(it is well worth anyone's time to spend a few hours learning a bit of
regex, the payback in saved time is enormous)
No. You may be able to achieve what you want with regexps. Otherwise,
you can process the output from g.mlist with additional programs.
Writing a regexp which matches the union of multiple patterns
(A OR B OR C) is straightforward enough; just use "(A|B|C)" with
extended regexps or '\(A\|B\|C\)' with basic regexps (care needs to be
taken to ensure that backslashes are passed verbatim rather than being
interpreted by the shell). There isn't an equivalent operator for
intersection or difference, but you can achieve the same result by
filtering the output with "grep" or "grep -v" respectively.
I'll have a look into regular expressions... sound very promissing
to me.
/johannes
-------- Original-Nachricht --------
Datum: Tue, 14 Feb 2012 20:01:44 +0000
Von: Glynn Clements <glynn@gclements.plus.com>
An: "Johannes Radinger" <JRadinger@gmx.at>
CC: GraSS user list <grass-user@lists.osgeo.org>
Betreff: Re: [GRASS-user] g.mlist with logical operators?
