Hi
I am using GRASS for a simulation which generates litrealy thousands
of layers. Before I start a new simulation, I want to delete all
existing layers, and I run into th following error message:
g.mremove -f rast=* vect=* region=*
Collecting map names for current mapset <simulation>...
Forcing ...
exec: 218: g.remove: Argument list too long
Is there anything I can do? except iterating through all layers and
deleting them separately?
And if no, How could I do this easily?
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
How about separating it in smaller chunks.
Try 3 comands first
g.mremove -f rast=*
g.mremove -f vect=*
g.mremove -f region=*
If you still get "argument list to long" you will have to split the
rast/vect/region list once more. I don't know how your rasters are
named but, for example, remove all that starts with the letter a
g.remove -f rast=a*
or some other division
Daniel
On Wed, Sep 24, 2008 at 10:27 AM, Rainer M Krug <r.m.krug@gmail.com> wrote:
Hi
Forcing ...
Thanks
Rainer
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, Sep 24, 2008 at 4:01 PM, Daniel Victoria
<daniel.victoria@gmail.com> wrote:
Try 3 comands first
g.mremove -f rast=*
g.mremove -f vect=*
That would not help much - all (except of a handfull of layers) are raster
g.remove -f rast=a*
That would be an option - but as it is used in a simulation, I don't
know for sure that not to many starting with a are created.
I therefore resorted to iterate through them:
for I in `g.mlist type=rast`;do g.remove $I; done
But in general, I would consider it a bug if an operation with
wildcard results in an error when to many are selected. I will file a
bug report for that.
Thanks
Rainer
Daniel
Hi
Forcing ...
Thanks
Rainer
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
I've bumped into this problem before, with the same error, but outside
GRASS. Which shows that this is not a GRASS bug but a limitation of
the operating system.
As for dividing the raster groups, probably your model output has some
sort of logic at how it names the raster (time period for example).
Use that to divide the groups. The starting with a was just a
suggestion...
Daniel
Try 3 comands first
g.mremove -f rast=*
g.mremove -f vect=*
g.remove -f rast=a*
Thanks
Rainer
Daniel
Hi
Forcing ...
Thanks
Rainer
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Try 3 comands first
g.mremove -f rast=*
g.mremove -f vect=*
g.remove -f rast=a*
There is a C replacement of the current scripts in the GRASS 6.x and GRASS 7.x development branches (see e.g. [1]).
Maybe you could just compile that and see if it solves the problem.
[1] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/general/g.mremove
Moritz
On Thu, Sep 25, 2008 at 9:13 AM, Moritz Lennert
Try 3 comands first
g.mremove -f rast=*
g.mremove -f vect=*
g.remove -f rast=a*
[1]
Moritz
Thanks - I'll do so on a later stage. For now I am iteratting...
Rainer
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Note that the C version relies upon new features in libgis
(specifically, in lib/gis/ls.c) and the build system, so you can't
just import general/g.mremove from SVN into 6.3.
However, there is also a standalone version (named g.xremove) in the
GRASS add-ons repository:
https://svn.osgeo.org/grass/grass-addons/general/g.xremove
Also, g.xlist:
https://svn.osgeo.org/grass/grass-addons/general/g.xlist
On Wed, Sep 24, 2008 at 5:04 PM, Daniel Victoria
AFAIK, to find the limit, you can run (file is from glibc-devel):
grep ARG_MAX /usr/include/linux/limits.h
#define ARG_MAX 131072 /* # bytes of args + environ for exec() */
It's more robust to use sysconf(_SC_ARG_MAX), as the limit isn't
necessarily fixed at compile time (e.g. it can vary between kernel
versions).
Also, the limit is divided between argv and the environment. If you
have a lot of space taken up by environment variables, it will eat
into the space available. This can be significant on older systems,
where the limit may be as low as 4KiB (a single page of memory).
