[GRASS-user] g.region crashing - grass6.2.2 and grass6.3
hi,
i've compiled grass6.2.2 and grass6.3 from source (2007/02/03) with the option --with-nls on suse 10.2.
starting g.region from gui or from cli, the g.region-tcl/tk-windows is crashing with the following error-messages:
GRASS 6.3.cvs (2007) – 03/02/2007 – compiled from source with --with-nls
starting g.region from gui or from cli:
bad window path name ".dialog11.nb.fGebe für Shell-Skript-Weiterverwendung aus"
    while executing
"frame $path.f$page -relief flat -background [Widget::getoption $path -background] -borderwidth 10"
    (procedure "NoteBook::insert" line 13)
    invoked from within
"NoteBook::insert .dialog11.nb end {Gebe für Shell-Skript-Weiterverwendung aus.} -text {Gebe für Shell-Skript-Weiterverwendung aus.}"
    ("eval" body line 1)
    invoked from within
"eval NoteBook::$cmd .dialog11.nb $args"
    (procedure ".dialog11.nb" line 1)
    invoked from within
"$path.nb insert end $label -text $label"
    (procedure "layout_make_frame" line 14)
    invoked from within
"layout_make_frame $dlg $guisection $optn"
    (procedure "layout_get_frame" line 4)
    invoked from within
"layout_get_frame $dlg $opt($dlg,$optn,guisection) $optn"
    (procedure "add_flag" line 19)
    invoked from within
"add_flag 9 {
name {g}
desc {Print in shell script style}
answer 0
label {}
guisection {Gebe für Shell-Skript-Weiterverwendung aus.}
    ("eval" body line 62)
    invoked from within
"eval $code"
    (procedure "run_ui" line 10)
    invoked from within
"run_ui $cmd"
    (procedure "execute" line 3)
    invoked from within
"execute g.region "
    invoked from within
".#menubar.#menubar#options.#menubar#options#menu1 invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tk::MenuInvoke" line 50)
    invoked from within
"tk::MenuInvoke .#menubar.#menubar#options.#menubar#options#menu1 1"
    (command bound to event)
GRASS 6.2.2.cvs (2007) – 03/02/2007 - compiled from source with --with-nls
bad window path name ".dialog0.nb.fGebe für Shell-Skript-Weiterverwendung aus"
    while executing
    invoked from within
"NoteBook::insert .dialog0.nb end {Gebe für Shell-Skript-Weiterverwendung aus.} -text {Gebe für Shell-Skript-Weiterverwendung aus.}"
    invoked from within
"eval NoteBook::$cmd .dialog0.nb $args"
    (procedure ".dialog0.nb" line 1)
    invoked from within
    invoked from within
    invoked from within
    invoked from within
"add_flag 10 {
name {g}
desc {Gib die aktuelle Region aus (Shell-Skript-Style).}
answer 0
label {}
guisection {Gebe für Shell-Skript-Weiterverwen..."
    ("eval" body line 69)
    invoked from within
"eval $code"
    (procedure "run_ui" line 16)
    invoked from within
"run_ui $cmd"
    invoked from within
"execute g.region "
    invoked from within
    invoked from within
    invoked from within
greetings from austria
best regards
helli
helmut kudrnovsky
www.alectoria.at
_____________________________________________________________________
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
