[GRASS-user] g.region error in compile grass (osge4w)
Hy,
I’ve compiled grass64 and grass65 without error following the istruction in http://trac.osgeo.org/grass/wiki/CompileOnWindows. If I run grass the system show a message like: “Unable to get current geographic extent. Force quiting wxGUI. Please run manualy g.region to fix the proble”.
If I run g.region I’ve this message: “g.region command not found”.
With make in g.region directory I’ve a compile error.
Could you help me?
ss
2009/3/31 sirius spelta <sirius.spelta@gmail.com>:
With make in g.region directory I've a compile error.
Could you help me?
well, we are not wizards :wink: Can you send error log?
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Exuse me,
I’ve attached the g.region make output in a txt file
thanks
ss
2009/3/31 Martin Landa <landa.martin@gmail.com>
Could you help me?
M.
(attachments)
make_g.region.out (7.55 KB)
Exuse me,
I've attached the g.region make output in a txt file
thanks
printwindow.c:3:22: projects.h: No such file or directory
PROJ4 library is missing or its header are not in the path.
M.
I’ve reinstalled proj4 library and all look ok!
thanks
ss
Exuse me,
thanks
M.
