[GRASS-user] g.remove error?
Hi all.
While running form the QGIS GRASS shell, I get:
GRASS > g.remove vect=random_butta
Removing vector <random_butta>
WARNING: Unable to remove directory
'/home/Documenti/datigrass/CEA_location/Cea_GRASS/.tmp/ursus/31318.0'
WARNING: couldn't be removed
WARNING: <random_butta> nothing removed
but the layer is in fact removed: any explanation for this?
Thanks a lot.
Paolo Cavallini wrote:
Hi all.
Vect_delete() renames the directory before deleting it. If the
deletion fails, you will get the above error. However, as the
directory has been renamed, it won't show up as a vector map.
Does the directory listed above exist? Does it contain any files or
subdirectories?
subdirectories?
Thanks Glynn for explaining. An nfs problem, apparently:
ls -la /home/Documenti/datigrass/CEA_location/Cea_GRASS/.tmp/ursus/31318.0/
totale 16
drwx--x--x 2 paolo paolo 4096 30 giu 17:45 .
drwx--x--x 11 paolo paolo 4096 30 giu 17:45 ..
-rw------- 1 paolo paolo 2914 30 giu 17:41 .nfs0000000000d9800100000006
-rw------- 1 paolo paolo 184 30 giu 17:41 .nfs0000000000d9800300000007
I have nfs-mounted homes. The .nfs* files are deleted correctly upon
QGIS closure.
All the best.
> subdirectories?
totale 16
QGIS closure.
Right. The reason why the directory is renamed is:
    /* NFS can create .nfsxxxxxxxx files for those deleted
     * -> we have to move the directory to ./tmp before it is deleted */
It appears that this isn't enough; but I have no idea what can be done
about it.
