g.remove -f type=vect name=huc12
WARNING: No data base element files found
and the map is not removed.
But, I can display the map, use the 'query' button in the display monitor,
and get the attribute information about individual hydrological units.
Why might g.remove fail this request?
Rich
Check if you are in the mapset where the map is, otherwise you cannot delete maps; i.e. maps can only be removed from the mapset they belong to
HTH
Vero
El mar., 10 jul. 2018 a las 20:44, Rich Shepard (<rshepard@appl-ecosys.com>) escribió:
But, I can display the map, use the ‘query’ button in the display monitor,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Vero,
Yes, that's probably the case.
Rich
