madi
January 25, 2013, 2:28pm
1
how to convert something like:
g.remove rast=g.mlist pat=r_start* sep=,
in python?
Thanks!
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
g.remove rast=`g.mlist pat=r_start* sep=,`
in python?
MaDi,
wouldn't a simple
# get list of r_start* raster maps -- split line-by-line
list_of_r_starts = grass.read_command('g.mlist', type= "rast" , pat =
"r_start*")
r_starts = list_of_r_starts.splitlines()
and then feed "g.mrenove" work for you?
Best, N
ps- sorry, old py-grass read_command in my example.
On 25/01/13 15:28, Margherita Di Leo wrote:
in python?
Try with g.mremove:
grass.run_command('g.mremove', rast='r_start*', flags='f')
Moritz
madi
January 25, 2013, 2:54pm
4
On Fri, Jan 25, 2013 at 3:46 PM, Moritz Lennert <mlennert@club.worldonline.be > wrote:
in python?
Try with g.mremove:
grass.run_command(‘g.mremove’, rast=‘r_start*’, flags=‘f’)
YESS!
Thanks!
Moritz
Margherita DI LEO
Via Fermi, 2749
Hi Margherita,
On Fri, Jan 25, 2013 at 3:28 PM, Margherita Di Leo <diregola@gmail.com> wrote:
in python?
GRASS7: r54769
from pygrass.modules import general as g
from pygrass.gis import Mapset
g.remove(vect=Mapset().glist('vect', pattern='points*'))
Removing vector <points04>
Removing vector <points01>
Removing vector <points02>
Removing vector <points00>
Removing vector <points03>
The method glist, of the Mapset class return a list of maps:
['points04', 'points01', 'points02', 'points00', 'points03']
