[GRASS-user] g.rename & wx GUI
Hi to all!
Just upgrade grass 6.4 from svn.
In wx GUI:
1)add vector map layer and set some properties
2)display it in map display
3)rename the vector (command line: g.rename vect...)
4)Re-render map in map display
5)get error msg "... Details:
Error: Vector map <pti@area> not found"
6)in Layer Manager ->properties ->"Name of imput vector map" set the
new name of vector map
7)try re-render map display: get nothing.
8)To display vector map (which is just renamed) I have to remove
vector layer from Gis Layer Manager (lost all setting properties) and
re-add.
Is it possible to avoid point 8 (map display refresh with the same
vector with new name)?
ciao
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
2009/1/18 Paolo Craveri <pcraveri@gmail.com>:
re-add.
fixed in r35482.
I was thinking to design dialog for managing data layers (copy,
rename, remove) with optional update of Layer tree (rename, remove).
But I am going to be busy and I am afraid it will be not better till
June. Any volunteer? :wink:
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
