[GRASS-user] G7-gui and G64 add-on problems on Xubuntu (installation from grass/ubuntugis ppa)
I want to install G7 and G6.4.3 as well as several add-ons on a freshly installed Xubuntu (12.04) machine (Virtualbox) for testing purposes. Therefore I run following commands after Xubuntu installation and update of the system:
sudo add-apt-repository ppa:grass/grass-devel
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install grass643 grass70 grass-gui grass70-gui
However after successful installation I run into following two problems:
  1. When I try to launch G7-gui (e.g. with standard NC example dataset) I get following error:
Launching GUI in the background, please wait…
GRASS 7.0.svn (nc_basic_spm_grass7):~ > Traceback (most recent call last):
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 143, in
sys.exit(main())
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 136, in main
app = GMApp(workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 50, in init
wx.App.init(self, False)
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 84, in OnInit
workspace = self.workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py”, line 108, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py”, line 40, in init
MenuTreeModelBuilder.init(self, filename, expandAddons=expandAddons)
File “/usr/lib/grass70/etc/gui/wxpython/core/menutree.py”, line 69, in init
xmlTree = etree.parse(filename)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1183, in parse
tree.parse(source, parser)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 657, in parse
self._root = parser.close()
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1655, in close
self._raiseerror(v)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1507, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
  1. G6.4.3. and its gui can be properly launched (no problems like mentioned in point 1). So here I tried to install add.ons. There I ran g.extension from the grass terminal but face following problem:
GRASS 6.4.3 (gisdemo_ncspm):~ > g.extension extension=r.stream.order
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)…
WARNING: gnome-keyring:: couldn’t connect to: /tmp/keyring-U4bRKD/pkcs11: No such file or directory
A r.stream.order/main.c
A r.stream.order/description.html
A r.stream.order/global.h
A r.stream.order/io.c
A r.stream.order/r_stream_order_orders.png
A r.stream.order/order.c
A r.stream.order/Makefile
U r.stream.order
Checked out revision 57991.
Compiling <r.stream.order>…
Makefile:12: /usr/lib/grass64/include/Make/Module.make: No such file or directory
make: *** No rule to make target `/usr/lib/grass64/include/Make/Module.make’. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
So does anyone have an idea what may cause the problems. I don’t think that the problems are related nor are they caused by my Xubuntu-Virtualbox setup. Do I miss any modules/packages/software that I need to install prior to grass? Or do I need to use different ppas for installing grass? Any help is of course mostly welcome!
Best regards,
Johannes
To be able to install grass addons in 6.4.3 you need to install the grass-dev package with sudo apt-get install grass-dev and then issue the g.extension command
Regards
2013/10/14 Johannes Radinger <johannesradinger@gmail.com>
sudo apt-get update
sys.exit(main())
self._raiseerror(v)
raise err
U r.stream.order
Best regards,
Johannes
grass-user mailing list
grass-user@lists.osgeo.org
César Augusto Ramírez Franco
Tecnólogo en Telecomunicaciones - ITM
Técnico certificado en Mantenimiento de Computadores - CESDE
Móvil: 301 389 5607
On Mon, Oct 14, 2013 at 12:19 PM, Cesar Augusto Ramírez Franco <
g.extension command
Maybe, GRASS, namely g.extension, should identify the error (e.g. check
the include/Make directory) and report an error with a suggestion (if on
linux: "Check that you have package ..."). But this might be very different
for various distributions.
Probably also the package description and suggested/related packages should
provide some information.
Regards
the system:
sudo apt-get update
1) When I try to launch G7-gui (e.g. with standard NC example dataset) I
Launching <wxpython> GUI in the background, please wait...
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 143, in <module>
    sys.exit(main())
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 136, in main
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 50, in __init__
    wx.App.__init__(self, False)
  File
"/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
7981, in __init__
  File
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 84, in OnInit
  File "/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py", line 108, in
__init__
  File "/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py", line 40, in
__init__
    MenuTreeModelBuilder.__init__(self, filename,
  File "/usr/lib/grass70/etc/gui/wxpython/core/menutree.py", line 69, in
__init__
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1183, in parse
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
    self._raiseerror(v)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
_raiseerror
    raise err
2) G6.4.3. and its gui can be properly launched (no problems like
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-U4bRKD/pkcs11:
U r.stream.order
Compiling <r.stream.order>...
directory
`/usr/lib/grass64/include/Make/Module.make'. Stop.
So does anyone have an idea what may cause the problems. I don't think
Best regards,
Johannes
*César Augusto Ramírez Franco*
Móvil: 301 389 5607
