[GRASS-user] gdal and grass new problem from "is, but isn't" series
Hi
gdal 1.3.2 and 1.3.1 grass 6.3 cvs (newest), Kubuntu 6.06 and ubuntu 6.06 with added KDE
after compilation of gdal over grass (without erros and warnings) when I try to run gdalinfo (or some other gdal utilities) message appears:
gdalinfo: error while loading shared libraries: libgrass_vect.so: cannot open shared object file: No such file or directory
of course libgrass_vect.so exist in /usr/local/grass6.3.cvs/lib/ as symlink to libgrass_vect.cvs.so
regards
Jarek
On Thu, Sep 21, 2006 at 09:25:18AM +0200, Jaros©©aw Jasiewicz wrote:
Hi
added KDE
Check if your PATH includes /usr/local/grass6.3.cvs/lib.
Huidae
regards
Jarek
grassuser mailing list
grassuser@grass.itc.it
> Hi
> added KDE
Did I say PATH? Sorry, it's LD_LIBRARY_PATH. If you cannot find the path,
add the following lines to your ~/.profile or ~/.bash_profile:
LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/local/grass6.3.cvs/lib"
export LD_LIBRARY_PATH
Huidae
Huidae
> regards
> Jarek
Huidae Cho napisa©©(a):
Hi
added KDE
Huidae
Huidae
regards
Jarek
unfortunatly not :frowning:
On Thu, 21 Sep 2006, [ISO-8859-2] Jaros³aw Jasiewicz wrote:
Hi
6.06 with added KDE
But is /usr/local/grass6.3.cvs/lib included in the directories "seen" by
ldconfig, and have you run ldconfig? I'm afraid that getting the plugins
set up is difficult, even though there is advice on:
http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
http://casoilresource.lawr.ucdavis.edu/drupal/node/123
Hope this helps,
Roger
regards
Jarek
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
Hi
6.06 with added KDE
I assume your gdal is installed under /usr/local.
Try adding the following 2 lines:
/usr/local/lib
/usr/local/grass-6.3.cvs/lib
to your /etc/ld.so.conf
Then run ldconfig as root.
/usr/local/lib is for gdal and other libs installed in your /usr/local,
/usr/local/grass-6.3.cvs/lib is for grass 6.3.
Maciek
> > added KDE
Alternatively, add /usr/local/grass6.3.cvs/lib to /etc/ld.so.conf then
run ldconfig (as root).
Maciej Sieczka napisa³(a):
Hi
6.06 with added KDE
/usr/local/lib
Maciek
Thanks, but I tried this
Jarek
