[GRASS-user] gdal, grass, and qgis
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
I tied compiling gdal with grass support for use with qgis, following
http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
and http://casoilresource.lawr.ucdavis.edu/drupal/node/123. Vectors go
well, but I cannot load grass rasters in qgis:
ERROR 4: `/home/Documenti/datigrass/Toscana/PERMANENT/cellhd/d260160'
not recognised as a supported file format.
However, gdalinfo can see the layer:
$ gdalinfo /home/Documenti/datigrass/Toscana/PERMANENT/cellhd/d260160
Driver: GRASS/GRASS Database Rasters (5.7+)
Size is 11530, 8919
Coordinate System is `'
Origin = (1599890.279998,4855983.000000)
Pixel Size = (0.63492801,-0.63437605)
Any hint on how to solve this?
All the best.
pc
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFErotT/NedwLUzIr4RAptxAJ49MsP+jYgLFjYjOYIimjPj7cqVCACfU15x
e8h7EPW2+GUGadf57Hh9nxc=
=OUU1
-----END PGP SIGNATURE-----
On Fri, 07 Jul 2006 18:26:59 +0200
Hash: SHA1
Hi all.
What versions? Using current Grass and Qgis CVS, Gdal 2006-02-10 and
gdal-grass 1.3.1.1 it works for me.
Size is 11530, 8919
At first I thought maybe the missing projection was the case but QGIS
reads my xy Grass rasters fine.
How about this:
reads: "New plugin version as of 19 Oct 2005, requires GDAL 1.3.1 or
later"
Are you sure your Gdal instalation is new enough?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
Hash: SHA1
Hi all.
Size is 11530, 8919
Paolo,
are you sure that QGIS uses the same GDAL installation (and sees
the plugin .so files)?
ldd may help to find out.
All the best.
pc
Paolo Cavallini
www.faunalia.it
=OUU1
grassuser mailing list
grassuser@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hash: SHA1
Ciao Markus.
Thanks for helping. I removed the previous gdal, so I think qgis is just
not using the new one.
How do I know this?
# ldd /usr/local/lib/gdalplugins/gdal_GRASS.so
        linux-gate.so.1 => (0xffffe000)
        libgrass_I.so => /usr/local/grass-6.1.cvs/lib/libgrass_I.so
(0xb7fc0000)
        libgrass_vask.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_vask.so (0xb7fba000)
        libgrass_gmath.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_gmath.so (0xb7fb4000)
        libgrass_gis.so => /usr/local/grass-6.1.cvs/lib/libgrass_gis.so
(0xb7f10000)
        libgrass_datetime.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_datetime.so (0xb7f08000)
        libgrass_gproj.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_gproj.so (0xb7f00000)
        libgrass_vect.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_vect.so (0xb7ecf000)
        libgrass_dbmibase.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_dbmibase.so (0xb7ec0000)
        libgrass_dbmiclient.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_dbmiclient.so (0xb7eb7000)
        libgdal.so.1 => not found
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7dd5000)
        libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7daf000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7da4000)
        libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7c6c000)
        libfftw.so.2 => /usr/lib/libfftw.so.2 (0xb7c40000)
        libz.so.1 => /usr/lib/libz.so.1 (0xb7c2b000)
        libncurses.so.5 => /lib/libncurses.so.5 (0xb7be9000)
        libproj.so.0 => /usr/lib/libproj.so.0 (0xb7bb4000)
        libgdal1.3.1.so.1 => /usr/lib/libgdal1.3.1.so.1 (0xb777f000)
        libgrass_dig2.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_dig2.so (0xb776d000)
        libgrass_dgl.so => /usr/local/grass-6.1.cvs/lib/libgrass_dgl.so
(0xb7756000)
        libgrass_rtree.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_rtree.so (0xb7751000)
        libgrass_linkm.so =>
/usr/local/grass-6.1.cvs/lib/libgrass_linkm.so (0xb774f000)
        /lib/ld-linux.so.2 (0x80000000)
        libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb774b000)
        libgeos.so.2 => /usr/lib/libgeos.so.2 (0xb7658000)
        libodbc.so.1 => /usr/lib/libodbc.so.1 (0xb75f8000)
        libxerces-c.so.26 => /usr/lib/libxerces-c.so.26 (0xb72a8000)
        libjasper-1.701.so.1 => /usr/lib/libjasper-1.701.so.1 (0xb725b000)
        libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0xb7239000)
        libdf.so.4 => /usr/lib/libdf.so.4 (0xb719a000)
        libungif.so.4 => /usr/lib/libungif.so.4 (0xb7192000)
        libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb7171000)
        libtiff.so.4 => /usr/lib/libtiff.so.4 (0xb711d000)
        libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb70f8000)
        libnetcdf.so.3 => /usr/lib/libnetcdf.so.3 (0xb70c4000)
        libcfitsio.so.2 => /usr/lib/libcfitsio.so.2 (0xb6f56000)
        libpq.so.4 => /usr/lib/libpq.so.4 (0xb6f39000)
        libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0xb6f25000)
        librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0xb6f1c000)
        libltdl.so.3 => /usr/lib/libltdl.so.3 (0xb6f15000)
        libicuuc.so.34 => /usr/lib/libicuuc.so.34 (0xb6e0a000)
        libicudata.so.34 => /usr/lib/libicudata.so.34 (0xb6595000)
        libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xb6555000)
        libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8
(0xb641b000)
        libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb639d000)
        libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb6378000)
        libcom_err.so.2 => /lib/libcom_err.so.2 (0xb6375000)
        libcrypt.so.1 => /lib/tls/i686/cmov/libcrypt.so.1 (0xb6347000)
        libresolv.so.2 => /lib/tls/i686/cmov/libresolv.so.2 (0xb6333000)
        libnsl.so.1 => /lib/tls/i686/cmov/libnsl.so.1 (0xb631d000)
        libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb6318000)
Markus Neteler wrote:
Paolo,
Paolo Cavallini
www.faunalia.it
iD8DBQFEr0h8/NedwLUzIr4RAkv2AKCifV8/SzJu4K83ROPJWaGaIVdPFwCeOBXc
D4cg7QsmBJA75QYpBPt4uDs=
=ro2M
Hash: SHA1
Hi Maciek.
Tanks for helping. I'm using grass+qgis from yesterday cvs/svn, gdal
1.3.2 stable, so it should be ok from this side.
pc
How about this:
later"
Maciek
Paolo Cavallini
www.faunalia.it
iD8DBQFEr0kO/NedwLUzIr4RAhKYAJ924Jm4bdBeslONIdQ3IkIBo78QgACeNuLr
ZT3/u35NzDV556T+3i+gRSM=
=WOZP
Hash: SHA1
I restarted from the beginning.
ln -s /usr/local/lib/libgdal.so.1 /usr/lib/libgdal1.3.1.so.1
did the job, although I do not know why qgis is looking for
/usr/lib/libgdal1.3.1.so.1 (it is compiled
- --with-gdal=/usr/local/bin/gdal-config and # gdal-config --version
1.3.2).
Anyway, now everything seems to be working well.
All the best.
pc
Ciao Markus.
Paolo Cavallini
www.faunalia.it
iD8DBQFEr2Rp/NedwLUzIr4RAnrhAKCX9QYSt5BRKGn32kGJ1E/dLgbPBgCfW/Dn
rl35DwEuYey01vZUtR1/PMg=
=mSvq
