[GRASS-user] GDAL-GRASS Error
When I run --with-grass=/usr/local/grass-6.5.svn, for installing GDAL-GRASS, I get the following error:
checking for gdal-config... /usr/bin/gdal-config
using /usr/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/grass-6.5.svn requested, but libraries not found!
Perhaps you need to set LD_LIBRARY_PATH to include /usr/local/grass-6.5.svn/lib?
I have created a **grass.conf** as instructed elsewhere inside /etc/ld.so.conf.d/ and have added following lines in it:
/usr/local/lib
I ran sudo ldconfig after that too.
I came across a similar issue posted in the [GRASS-Dev mailing list](http://osgeo-org.1803224.n2.nabble.com/gdal-grass-plugin-build-failed-td6232215). As an answer it was instructed to:
You could just generate the symlinks yourself, e.g.:
cd /usr/local/grass-6.5.svn/lib
    for file in libgrass_*.so ; do ln -s $file ${file%.[6.5.svn.so](http://6.5.svn.so)}.so ; done html.
I ran,
but it made no difference! What should I do now?
Thanks and Regards,
Chethan S.
On Mon, May 2, 2011 at 3:01 PM, Chethan S <chethanuniversal@gmail.com> wrote:
Above problem was a temporary mess which has been fixed since then:
See http://trac.osgeo.org/grass/changeset/46104
I wonder why 6.5 is lacking this fix.
2011/5/2 Markus Neteler <neteler@osgeo.org>:
I will apply the fix ASAP (when I will be able to commit the patch)
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
