[GRASS-user] gdal + grass truble
Dear all grass users,
I have some problem using configuring qgis and grass.
After installing grass (It works fine!!) I want to install qgis with grass
support, so i follow the information in:
http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
So i try to compile gdal-grass and I have this error:
ogrgrasslayer.cpp: In destructor 'virtual OGRGRASSLayer::~OGRGRASSLayer()':
ogrgrasslayer.cpp:243: error: 'class OGRFeatureDefn' has no member named
'Release'
ogrgrasslayer.cpp:245: error: 'class OGRSpatialReference' has no member named
'Release'
make: *** [ogrgrasslayer.o] Error 1
In fact wheh I run:
  export CPL_DEBUG=on
and then
ogrinfo -summary /home/pierluigi/DATABASEGRASS/spearfish60/P
ERMANENT/vector/roads/head
OGR:
OGROpen(/home/pierluigi/DATABASEGRASS/spearfish60/PERMANENT/vector/roads/he
ad) failed.
OGR:
ad) failed.
FAILURE:
Unable to open datasource
`/home/pierluigi/DATABASEGRASS/spearfish60/PERMANENT/v
ector/roads/head' with the following drivers.
can anyone help me??
P.S. I'm using mandriva linux...
Pierluigi
Pierluigi De Rosa
Department of Enviromental & Civil engineering
Faculty of Engineering
Perugia (Italy)
After installing grass (It works fine!!) I want to install qgis with grass support, so i follow the information in:
ogrgrasslayer.cpp:243: error: 'class OGRFeatureDefn' has no member named 'Release'
ogrgrasslayer.cpp:245: error: 'class OGRSpatialReference' has no member named 'Release'
Pierluigi,
It looks like there is a mixture of versions. Perhaps you have an old
(pre 1.3.0) GDAL/OGR with a newer grass driver? I would encourage upgrading
to at least GDAL/OGR 1.3.1 and preferrable GDAL/OGR 1.3.2 to use the GRASS
vector driver.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGF, http://osgeo.org
