[GRASS-user] gdal_version.h for gdal-1.2.5-1.i586.rpm
GRASS Users:
The only GDAL RPM I found which does NOT fail dependencies when installing under RHEL3/CentOS3 is an older one which I downloaded a while back, which I can NOT locate now in my Web Searching: gdal-1.2.5-1.i586.rpm (which was for an older Release of GRASS, possibly for a SuSE 9x Build of GRASS6.0???):
Name : gdal Relocations: /usr/local
Version : 1.2.5 Vendor: GDF Hannover bR <http://www.gdf-hannover.de>
Release : 1 Build Date: Mon 07 Feb 2005 08:15:39 AM EST
Install Date: (not installed) Build Host: tatzi
Group : Applications/GIS Source RPM: gdal-1.2.5-1.src.rpm
Size : 10267601 License: MIT licence; Copyright by Frank Warmerdam
Signature : (none)
Packager : Otto Dassau <info@gdf-hannover.de>
URL : http://gdal.org/
Summary : GDAL - a translator library for raster geospatial data formats
Description :
GDAL is a translator library for raster geospatial data formats. As a library,
it presents a single abstract data model to the calling application for all
supported formats. An initial skeleton of GDAL has formed, and operates for a
few formats.
Although configure is satisfied with the presence of GDAL, at build time there is a missing "gdal_version.h" which causes some of the Vector Modules to fail at compile time... I fashioned an "gdal_version.h" after the "gdal_version.h" included within the newer GDAL RPMs, after which my GRASS 6.2.1 Build reports NO Errors??? My hand crafted "gdal_version.h" looks as follows:
/* GDAL Version Information. */
#ifndef GDAL_VERSION_MAJOR
# define GDAL_VERSION_MAJOR 1
# define GDAL_VERSION_MINOR 2
# define GDAL_VERSION_REV 5
# define GDAL_VERSION_BUILD 1
#endif
#ifndef GDAL_VERSION_NUM
# define GDAL_VERSION_NUM (GDAL_VERSION_MAJOR*1000+GDAL_VERSION_MINOR*100+GDAL_VERSION_REV*10+GDAL_VERSION_BUILD)
#endif
#ifndef GDAL_RELEASE_DATE
# define GDAL_RELEASE_DATE 20041121
#endif
#ifndef GDAL_RELEASE_NAME
# define GDAL_RELEASE_NAME "1.2.5.1"
#endif
Should GRASS 6.2.1 built against GDAL 1.2.5 produce Vector Routines which will perform "correctly" or should it be built against a newer version (in spite of being unable to find a RPM which does NOT fail dependencies installing under RHEL3/CentOS3??? Could the GRASS 6.2 Code be made smart enough the be able to handle the lack of a "gdal_version.h" for GDAL 1.2.5 (previous GRASS Releases did build without errors against this "older" version of GDAL)???
Lawrence Houston -- (grass@greenfield.dyndns.org)
Hi Lawrence,
the rpm is pretty old and was compiled on a Suse 9.1 (June, 2005). The
dependencies probably don't fail because there aren't really any included in
the SPEC file, except these:
BuildRequires: proj, python, zlib-devel
Requires: proj, zlib, python
BTW: the related GRASS package was grass-6.0.0.
Maybe you should create your own gdal rpm for RHEL3/CentOS3 with a appropriate
SPEC file or somebody has a matching package for your distribution. The gdal
1.2.5 suse package is not a good choice - I think...
Maybe you can adapt a fedora4 spec file to your needs from here:
http://grass.itc.it/grass62/binary/linux/
regards,
Otto
On Tue, 23 Jan 2007 23:10:45 -0500 (EST)
Lawrence Houston <grass@greenfield.dyndns.org> wrote:
GRASS Users:
GRASS6.0???):
08:15:39 AM EST
Signature : (none)
formats
Description :
few formats.
looks as follows:
#endif
N_BUILD)
#endif
#endif
#endif
version of GDAL)???
grassuser mailing list
grassuser@grass.itc.it
