[GRASS-user] Generalizing SRTM DEM for hillshading
Dear all,
I'm trying to generalize the 90m SRTM DEM for use in cartography, e.g. for a hillshading in a 1:700.000 map. Emphasis is on a good-looking map, not on a hydrologic correct model.
For this scale, there is too much detail in the SRTM DEM, so I tried different filtering approaches: r.neigbors, r.resample.rst and other methods like resolution-bumping, but the output looks to soft: all the main ridges, which should give a quite crisp image have disappeared. I would like to keep the main structures (like high peaks and long ridges) and drop the small structures like short ridges, small gullys and channels.
I know, automated generalizing of elevation models is one of the biggest topics in modern cartography, but maybe someone has a good hint :slight_smile:
Thanks in advance, Lars
On Tue, Jun 20, 2006 at 03:17:43PM +0200, Lars Pennig wrote:
Dear all,
Hi Lars,
what about r.contours (use cut= to avoid tiny lines), and then
v.surf.rst?
On Tue, 20 Jun 2006 15:35:25 +0200
v.surf.rst?
For a predictable DEM from contours, I'd recommend r.surf.nnbathy (see
WIKI).
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
On 6/21/06, maning sambale <emmanuel.sambale@gmail.com> wrote:
I tried making a script creating a multidirectional, oblique-weighted,
shaded-relief image from an input DEM image. Might be useful.
link:
http://esambale.wikispaces.com/hillshade+multi
Maning
> > v.surf.rst?
> WIKI).
> Maciek
> ZAPRASZAMY
> www.skarpatravel.pl
> grassuser mailing list
> grassuser@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |www.esambale.wikispaces.com|
| _)_/LI |www.geocities.com/esambale/philbiodivmap/philbirds.html |
