leonidas wrote:
I need to generate a DEM using a line vector file (contours,
step=20m, some are disjoined) and also combine a second point
vector file with heights.How can I achieve that with Grass?
v.to.rast + r.surf.contour
In the contours file there is also the coastline (height=0).Will
that produce any error?
yes, please read the r.surf.contour help page carefully about
that.
the quick workaround is to use r.mapcalc to multiply your raster
input with:
r.mapcalc "contline_mult = (contlines*100000)+1"
then run r.surf.contour
then reverse the above multiplication:
r.mapcalc "dem = (contour_dem -1) / 100000"
besides that pain r.surf.contour does a really nice job.
Hamish
I don't know if r.surf.contour is suitable for my data because there are
disjointed contour lines and spot elevation data between contour lines. So
according to the manual of r.surf.contour:"Violating these constraints will
cause non-intuitive anomalies to appear in the output map". Is there any
other tool appropriate for my data?Unfortunately there is no time to fix the
data.
that.
input with:
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/Generate-DEM-with-point-and-line-vector-tp2976281p3037948.html
