[GRASS-user] geodatabase or shapefile?
   US National Wetland Inventory datasets are available in two flavors:
geodatabase and shapefile. What are the benefits of one format over the
other for use with grass, other than the former being much smaller
(compressed) than the latter?
Rich
Rich,
Have you figured out a way to read a geodatabase in GRASS? I think it can be done in R, and with rgrass7 you can probably bring the data into GRASS. Shapefiles are pretty straight forward in GRASS.
Tom
On Tue, May 29, 2018 at 7:10 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Rich
grass-user mailing list
grass-user@lists.osgeo.org
I have had success reading data from geodatabases in R and QGIS, but only
vector layers. If they have embedded rasters you will need Arc to get them
out.
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
Thomas,
   Yes. The input must be selected as a directory, not a file. I know this
because last year I started a thread on using geodatabase files and was
shown how to do it by those who know. I'm sure it's in the mail list
archives. For some reason I'm not finding it in my local grass mail file.
Rich
out.
   As I responded to Thomas, they are easily imported into grass-7 as
directories, not files. I don't recall off-hand the specifics but the
discussion thread is probably in the mail list archive from last year.
Rich
On Wed, May 30, 2018 at 2:04 AM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
out.
directories, not files. I don’t recall off-hand the specifics but the
See the GDAL documentation on ESRI File Geodatabase [0]
Markus M
[0] http://gdal.org/drv_openfilegdb.html
Rich
On Wed, 30 May 2018, Markus Metz wrote:
See the GDAL documentation on ESRI File Geodatabase:
Markus,
   Thanks for the URL. It's been a while since I used a .gdb so having a
reverence is really helpful.
   Back to my thread's question: Technically (other than compressed file
size), are there advantages to using the .gdb over the .shp?
Best regards,
Rich
2018-05-30 14:57 GMT+02:00 Rich Shepard <rshepard@appl-ecosys.com>:
see http://switchfromshapefile.org/
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Ma,
   Thank you. That effectively answers my question.
   I miss the old .e00 format (used with GRASS-4.x) which had (still has) two
advantages over shape files: 1) it includs topography and 2) it's in plain
text easily read by humans and computers.
Best regards,
Rich
   That's a great read!
   Seeing the 255 attribute limit brought to mind the original ARC/Info
(which I used on a Prime and on early PCs in the late 1980s and early
1990s). Info was limited to 1024 characters per row which was often a
serious constraint for environmental analyses.
Rich
