[GRASS-user] Geomorphons and extension manager
To whom it may concern,
I am trying to use extension manager in grass to install geomrphons. However, I am having trouble with the extension manager(error below). I emailed the geomorphon developer Jarek Jasiewicz(See Below) and he suggest I contact the GRASS-Users forum.
Please advise,
-Robert Brown
Subject: Re: Geomorphons
Date: February 26, 2013 11:56:20 AM EST
To: brown782@purdue.edu
On 02/26/2013 05:21 PM, brown782@purdue.edu wrote:
Dear Sir,
I use grass on my Mac OS X 10.8.2. I have been trying to compile grass to install the add-on Geomorphons. However, it is overwhelming to compile grass from source code as I have very little experience compiling programs. When I saw that your Geomorphons algorithm was part of the grass 7.0 add-ons I was pleased and tried to use the extension manager to add it to my grass add-on repository, however, I get an several errors which I have posted below. Any Suggestions?
g.extension extension=r.geomorphon/ operation=add
Fetching <r.geomorphon/> from GRASS-Addons SVN (be patient)…
Compiling…
In file included from geom.c:1:
local_proto.h:1:20: error: stdlib.h: No such file or
directory
local_proto.h:2:20: error: string.h: No such file or
directory
local_proto.h:3:18: error: math.h: No such file or directory
local_proto.h:4:27: error: grass/glocale.h: No such file or
directory
local_proto.h:5:23: error: grass/gis.h: No such file or
directory
local_proto.h:6:26: error: grass/raster.h: No such file or
directory
local_proto.h:56: error: expected specifier-qualifier-list
before ‘RASTER_MAP_TYPE’
local_proto.h:66: error: expected specifier-qualifier-list
local_proto.h:74: error: expected specifier-qualifier-list
before ‘CELL’
local_proto.h:139: error: expected declaration specifiers or
‘…’ before ‘RASTER_MAP_TYPE’
local_proto.h:140: error: expected ‘)’ before ‘’ token
geom.c: In function ‘exposition’:
geom.c:146: warning: incompatible implicit declaration of
built-in function ‘fabs’
geom.c: In function ‘extends’:
geom.c:206: warning: incompatible implicit declaration of
geom.c: In function ‘shape’:
geom.c:232: warning: incompatible implicit declaration of
built-in function ‘atan’
geom.c:236: warning: incompatible implicit declaration of
built-in function ‘sin’
geom.c:237: warning: incompatible implicit declaration of
built-in function ‘cos’
directory
directory
directory
directory
directory
before ‘CELL’
local_proto.h:140: error: expected ‘)’ before '
’ token
lipo: can’t figure out the architecture type of: /var/folder
s/wc/2dv9njw93k3bfyy5ppkw022h0000gn/T//ccESKY4a.out
make: *** [OBJ.x86_64-apple-darwin12.2.0/geom.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
(Tue Feb 26 09:40:18 2013) Command finished (3 sec)
Your help is much appreciated!
Sincerely,
Robert Brown
All messages comes from compiler informing you haven’t installed standard librarires. This is however the issue of g.extension, which do not work well with Apple systems. Please contact grass dev team how to resolve this issue
regards
Jarek
When I tried to compile r.geomorphon, I got the errors you see below. I just tried g.extensions with similar results.
$ make MODULE_TOPDIR=/home/bob/dev/gis/grass70
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
gcc  -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include  -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/geom.o -c geom.c
geom.c: In function ‘ternary_rotate’:
geom.c:21:5: warning: unused variable ‘res’ [-Wunused-variable]
geom.c: In function ‘radial2cartesian’:
geom.c:188:21: warning: ordered comparison of pointer with integer zero [-Wextra]
geom.c:198:37: warning: unused parameter ‘pattern_size’ [-Wunused-parameter]
geom.c: At top level:
geom.c:2:15: warning: ‘dirs’ defined but not used [-Wunused-variable]
gcc  -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include  -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:177:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:198:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:207:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:213:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:220:3: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:234:3: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:310:8: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:366:5: error: implicit declaration of function ‘radial2cartesian’ [-Werror=implicit-function-declaration]
main.c:401:2: error: implicit declaration of function ‘write_contrast_colors’ [-Werror=implicit-function-declaration]
main.c:268:20: warning: unused variable ‘formC’ [-Wunused-variable]
main.c:268:13: warning: unused variable ‘formB’ [-Wunused-variable]
main.c:268:6: warning: unused variable ‘formA’ [-Wunused-variable]
main.c:76:22: warning: unused variable ‘radius’ [-Wunused-variable]
main.c:74:11: warning: unused variable ‘n’ [-Wunused-variable]
main.c:74:8: warning: unused variable ‘j’ [-Wunused-variable]
main.c:463:1: warning: control reaches end of non-void function [-Wreturn-type]
cc1: some warnings being treated as errors
make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1
From: grass-user-bounces@lists.osgeo.org [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Robert Andrew Brown
Sent: Tuesday, February 26, 2013 9:21 AM
To: grass-user@lists.osgeo.org
Cc: Phillip Owens
Subject: [GRASS-user] Geomorphons and extension manager
Please advise,
-Robert Brown
Dear Sir,
Compiling…
directory
directory
directory
directory
directory
before ‘CELL’
directory
directory
directory
directory
directory
before ‘CELL’
’ token
Sincerely,
Robert Brown
regards
Jarek
| Hi,
missing function definitions added in svn with r55235 & now it builds. I’ll leave the other compiler warnings for the authors to look at …
Hamish
— On Tue, 2/26/13, Moskovitz, Bob@DOC Bob.Moskovitz@conservation.ca.gov wrote:
> From: Moskovitz, Bob@DOC Bob.Moskovitz@conservation.ca.gov
> Subject: Re: [GRASS-user] Geomorphons and extension manager
> To: “Robert Andrew Brown” brown782@purdue.edu, “grass-user@lists.osgeo.orggrass-user@lists.osgeo.org
> Cc: “Phillip Owens” prowens@purdue.edu, “jarekj@amu.edu.pl” jarekj@amu.edu.pl
> Date: Tuesday, February 26, 2013, 3:38 PM
> <br>> $ make MODULE_TOPDIR=/home/bob/dev/gis/grass70<br>>
> <br>> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu<br>>
> <br>> gcc -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/geom.o -c geom.c<br>>
> <br>> geom.c: In function ‘ternary_rotate’:<br>>
> <br>> geom.c:21:5: warning: unused variable ‘res’ [-Wunused-variable]<br>>
> <br>> geom.c: In function ‘radial2cartesian’:<br>>
> <br>> geom.c:188:21: warning: ordered comparison of pointer with integer zero [-Wextra]<br>>
> <br>> geom.c: In function ‘extends’:<br>>
> <br>> geom.c:198:37: warning: unused parameter ‘pattern_size’ [-Wunused-parameter]<br>>
> <br>> geom.c: At top level:<br>>
> <br>> geom.c:2:15: warning: ‘dirs’ defined but not used [-Wunused-variable]<br>>
> <br>> gcc -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c<br>>
> <br>> main.c: In function ‘main’:<br>>
> <br>> main.c:177:2: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:198:2: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:207:2: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:213:2: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:220:3: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:234:3: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:310:8: warning: format not a string literal and no format arguments [-Wformat-security]<br>>
> <br>> main.c:366:5: error: implicit declaration of function ‘radial2cartesian’ [-Werror=implicit-function-declaration]<br>>
> <br>> main.c:401:2: error: implicit declaration of function ‘write_contrast_colors’ [-Werror=implicit-function-declaration]<br>>
> <br>> main.c:268:20: warning: unused variable ‘formC’ [-Wunused-variable]<br>>
> <br>> main.c:268:13: warning: unused variable ‘formB’ [-Wunused-variable]<br>>
> <br>> main.c:268:6: warning: unused variable ‘formA’ [-Wunused-variable]<br>>
> <br>> main.c:76:22: warning: unused variable ‘radius’ [-Wunused-variable]<br>>
> <br>> main.c:74:11: warning: unused variable ‘n’ [-Wunused-variable]<br>>
> <br>> main.c:74:8: warning: unused variable ‘j’ [-Wunused-variable]<br>>
> <br>> main.c:463:1: warning: control reaches end of non-void function [-Wreturn-type]<br>>
> <br>> cc1: some warnings being treated as errors<br>>
> <br>> make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1<br>>
> Cc: Phillip Owens
> Please advise,
> -Robert Brown
> From: JASIEWICZ Jarosław jarekj@amu.edu.pl
> Dear Sir,
> > > Compiling…
> > > directory
> > > directory
> > > directory
> > > directory
> > > directory
> > > before ‘CELL’
> > > directory
> > > directory
> > > directory
> > > directory
> > > directory
> > > before ‘CELL’
’ token
> > > Sincerely,
> > > Robert Brown
> regards
> Jarek
> -----Inline Attachment Follows-----
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hello,
I appreciate the fast action on the dealing with the geomorphon issue. However I again tried to use extension manager to install the add-on and got the following warning.
(Wed Feb 27 09:20:40 2013)
g.extension extension=r.geomorphon operation=add
Fetching <r.geomorphon> from GRASS-Addons SVN (be patient)…
Compiling…
directory
directory
directory
directory
directory
local_proto.h:57: error: expected specifier-qualifier-list
local_proto.h:68: error: expected specifier-qualifier-list
local_proto.h:77: error: expected specifier-qualifier-list
before ‘CELL’
local_proto.h:146: error: expected declaration specifiers or
local_proto.h:147: error: expected ‘)’ before ‘’ token
geom.c:149: warning: incompatible implicit declaration of
geom.c:213: warning: incompatible implicit declaration of
geom.c:240: warning: incompatible implicit declaration of
geom.c:244: warning: incompatible implicit declaration of
geom.c:245: warning: incompatible implicit declaration of
directory
directory
directory
directory
directory
before ‘CELL’
local_proto.h:147: error: expected ‘)’ before '
’ token
s/wc/2dv9njw93k3bfyy5ppkw022h0000gn/T//ccJFVReJ.out
(Wed Feb 27 09:20:45 2013) Command finished (5 sec)
Any help would be much appreciated!
Sincerely,
-robert brown
On Feb 27, 2013, at 12:48 AM, Hamish <hamish_b@yahoo.com> wrote:
| Hi,
Hamish
— On Tue, 2/26/13, Moskovitz, Bob@DOC <Bob.Moskovitz@conservation.ca.gov> wrote:
> From: Moskovitz, Bob@DOC <Bob.Moskovitz@conservation.ca.gov>
> To: “Robert Andrew Brown” <brown782@purdue.edu>, “grass-user@lists.osgeo.org” <grass-user@lists.osgeo.org>
> Cc: “Phillip Owens” <prowens@purdue.edu>, “jarekj@amu.edu.pl” <jarekj@amu.edu.pl>
> Cc: Phillip Owens
> Please advise,
> -Robert Brown
> Dear Sir,
> > > Compiling…
> > > directory
> > > directory
> > > directory
> > > directory
> > > directory
> > > before ‘CELL’
> > > directory
> > > directory
> > > directory
> > > directory
> > > directory
> > > before ‘CELL’
’ token
> > > Sincerely,
> > > Robert Brown
> regards
> Jarek
some compilation errors should be fixed in r55243.
directo
seems like standard header are missing on your computer. Try to install them, eg. on Debian/Ubuntu
sudo apt-get install libc6-dev
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Sorry to be a pain,
So I have deleted the binary and tried to compile grass from source code. I am getting an error which is the same error that I have been getting after several hundred hours of tying to compile grass which is why I stopped trying to compile it. I installed Cairo through the GRASS http://www.kyngchaos.com/software:frameworks. The error is…
Unable to locate cairo_create
The ./configure script I am using is…
–with-cairo --with-cairo-includes=“/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include” --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags=“-lcairo”
I have seen this error issue as far back as 2011.
Does anyone have any suggestions to a fix around?
-robert brown
On Feb 27, 2013, at 10:02 AM, Martin Landa <landa.martin@gmail.com> wrote:
directo
Martin
