[GRASS-user] Georectify problem
I am trying to georectify an xy image. I think that I am doing things correctly yet I keep getting an error. Perhaps someone can clear things up for me.
I imported the image into an XY location. I then went to the location that I want to import into and brought up a map so I could click on points.
If then select file-> georectify. I fill in the info and then click Start georectifying. It brings up the manage ground control points window and a display showing the xy map to be georectified. If I click there I can add the GCP xy coords. But if I then click in my original window to select the georgraphic coords I get an error: can't read "b1 coords" : no such variable.
can't read "b1coords": no such variable
    while executing
"$geoentry insert 0 $b1coords"
    invoked from within
"if { [info exists geoentry] } {
    (command bound to event)
I can't figure out why it will not let me select the points. I have selected the arrow tool in the map display.
I am using a Mac with William Kyngesburye's binary builds. I have 6.4 RC5-3 Snow with OS 10.6.2
--Adam
