[GRASS-user] geotiff and tiff exprot
Hi all :
In fact I have post this question,but not got a answer/
I am using win grass 6.3, when export the raster data to tiff ,I can use two command >
1
  1. r.out.gdal use this command the tiff I got is blank,and I am sure that this tiff has the correct crs, since I have use the gdalinfo command to test the black blank tiff.
  2. r.tiff use this command the tiff I got has not crs (Coordinate System),although I can see the data(the lines of the road, it is not blank).
And before I export the data,I use the g.region command to identifier the region.
So ,I wonder the problem is my fault or something else.
