[GRASS-user] GeoTIFF output question (number of bytes divisible by 8?)
I am using
r.out.tiff -t input=fcms@PERMANENT output=/home/ssefick/Desktop/fcms.tiff
for input into the tauDEM pitremove function (compiled from source)
and I am getting a
Must be multiple of 8 (a byte) error
I know that this is not a part of GRASS, but I was wondering if some
knew how to make the output of the GRASS command export a compliant
GEOTIFF
thanks for all of your help,
Stephen Sefick
____________________________________
| Auburn University |
| Department of Biological Sciences |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
|___________________________________|
| sas0025@auburn.edu |
| http://www.auburn.edu/~sas0025 |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
                            \-K\. Mullis
stephen sefick wrote:
I am using
Use
r.out.gdal input=fcms@PERMANENT output=/home/ssefick/Desktop/fcms.tiff
BTW, with r.out.tiff you get a standard tiff image with color values
(0 - 255, 3 bands for RGB), not elevation values.
Markus M
Thank you- I will figure all of this out one day... I thank you all
for your kind support.
kindest regards,
Stephen Sefick
On Mon, Aug 9, 2010 at 8:05 AM, Markus Metz
I am using
Use
Markus M
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
If anyone is interested I had to export the files in AAIGrid format
with a no data value =0 (elevations well above sea level) and then use
gdal_translate to turn this into a geotiff.
GRASS GIS out
nodata=0 format=AAIGrid
#translate to goetiff
gdal_translate -of GTIFF fcms fcms_g.tiff
then tauDEM command line functions seem to work fine.
If I am missing something please inform me.
Again, thanks for all of the help!
Stephen Sefick
kindest regards,
Stephen Sefick
I am using
Use
Markus M
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
Why did export directly to GeoTIFF not work?
GRASS GIS out
Stephen Sefick
kindest regards,
Stephen Sefick
I am using
Use
Markus M
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
no data not defined is the error message with a straight write out in
geotiff when fed into tauDEM.
I am at a loss for why this would not work.
On Mon, Aug 9, 2010 at 9:36 AM, Markus Metz
GRASS GIS out
Stephen Sefick
kindest regards,
Stephen Sefick
I am using
Use
Markus M
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
                            \-K\. Mullis
