[GRASS-user] get coords from a raster
Hi List,
I’m trying to make a script to calculate the slope along a path. I want to calculate the slope as the average of cell per cell slope. For my purpose I found r.profile to produce the input file for my script, but I have to give it the coordinates of the points. As I have a raster and not a vector, I was wondering if is there a non interactive way like a d.where or something like that, that i can use for my purpose. I mean, i have a raster in which there is the path i’m interested in, and the other cells are null.
Thank you in advance
Margherita
Christian,
thank you for answering. My problem is that I don’t want to use the slope map to get slope, bu i want to calculate it as the
ratio between the difference of the elevation and the distance between two given points (pixels). To do that, I need to get the coordinates of the points as a input file for r.profile.
Margherita
2010/6/2 Christian Schwartze <christian.schwartze@uni-jena.de>
Why are you not using r.statistics, since it takes one base map (your path as a raster) and another map containing data you want to analyze (your slope). With the “average” option/method you will get the desired result, if I understand you correctly…
Christian.
Sent: Wednesday, June 02, 2010 6:17 PM
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] get coords from a raster
Hi List,
Margherita
grass-user mailing list
On Wed, Jun 2, 2010 at 6:50 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Christian,
thank you for answering. My problem is that I don't want to use the slope
If you treat them as vectors, perhaps this could help?
v.to.db
             slope: slope steepness of vector line or boundary
Markus,
Thank you. I’m pretty sure this is the way. So I run:
r.to.vect input=mainchannel output=points feature=point --o
v.to.db map=points option=coor col=x,y (like the man page suggests)
but I get a number of errors like:
Column ‘x’ not found
Error in db_execute_immediate()
where am I wrong now?
2010/6/2 Markus Neteler <neteler@osgeo.org>
v.to.db
I calculate slope as
S = (z2-z1)/(sqrt((x2-x1)^2+(y2-y1)^2))*100
where x1,y1 are the coords of point 1, x2,y2 are the coords of point 2, and z1, z2 are the elevations in the raster map associate at the points 1 and 2 respectively.
Margherita
On Wed, Jun 2, 2010 at 10:07 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Markus,
Thank you. I'm pretty sure this is the way. So I run:
Column 'x' not found
Two times v.db.addcol is missing for the x and y columns (before v.to.db).
Margherita,
now I got your point…I had a very similar problem a short time ago, but finally I was able to solve it. If your are interested in, take a look to the following notes - I know, a bit complicated but it works Zwinkerndes Smiley Emoticon
  • set your desired path as a mask for limiting following calculations using r.mask
  • r.describe -dr <your_dem> to fetch min and max of elevation along your path (use tool awk or any other string processing function like split() in Python)
  • r.to.vect to convert the mask into a vector line, and then v.to.db -p <your_vector_path> option=length column=s to print out the path length (therefor, parse the string again to fetch the column that contains the length)
  • now you can calculate the slope based on altitude difference and distance…
Perhaps it is adaptable to yours…
Christian.
Sent: Wednesday, June 02, 2010 6:50 PM
To: Christian Schwartze
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] get coords from a raster
Christian,
Margherita
Christian.
Hi List,
Margherita
Thank you everyone for your help. As always, GRASS offers many possibilities to do anything. I solved with r.out.xyz.
Best,
Margherita
2010/6/3 Christian Schwartze <christian.schwartze@uni-jena.de>
Margherita,
Christian.
Christian,
Margherita
Christian.
Hi List,
Margherita
