[GRASS-user] Get current location projection in a Python Script
On May 25, 2010, at 1:29 AM, grass-user-request@lists.osgeo.org wrote:
Date: Tue, 25 May 2010 08:50:10 +0100
Subject: [GRASS-user] Get current location projection in a Python
  Script
To: grass-user@lists.osgeo.org
Message-ID:
  <AANLkTinVGIHZ3X8oStE4MWkdynHjPZyAo_Ve4KcvZs2U@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Greetings
I'm building a GRASS Python Script to automatically import a set of data to
my location. At GRASS book (chapter 3.3.3) it uses g.proj -wf to to check
current location projection. Can I use the same command in Python to
retrieve the same?
And how about calling gdalwarp in a Python-GRASS Script? can it be called
and used by a Python_GRASS Script? if so, is there any Python example with
that?
Regarding "g.proj -wf" command. I get a lot of information. I suppose
GDALWARP can read this right ? If not, How can I obtain current Location
EPSG code?
Thanks
Best regards,
Kim
Use the region() command from the GRASS Python library. <http://download.osgeo.org/grass/grass6_progman/pythonlib.html&gt;
Michael
Kim Besson:
> to my location. At GRASS book (chapter 3.3.3) it uses g.proj -wf to to
> check current location projection. Can I use the same command in Python
> to retrieve the same?
> with that?
> EPSG code?
Michael Barton:
Just for the records, a thread not _directly_ about it but close (enough?):
<http://osgeo-org.1803224.n2.nabble.com/Getting-rows-cols-of-a-region-in-a-
script-tc2787474.html#a2788062>
Nikos
On May 25, 2010, at 8:25 AM, Nikos Alexandris wrote:
Kim Besson:
with that?
EPSG code?
Michael Barton:
Nikos
The thread is for BASH and does not work for Python.
Michael
Kim Besson:
>>> data to my location. At GRASS book (chapter 3.3.3) it uses g.proj -wf
>>> to to check current location projection. Can I use the same command in
>>> Python to retrieve the same?
>>> called and used by a Python_GRASS Script? if so, is there any Python
>>> example with that?
>>> Location EPSG code?
Michael Barton:
Nikos Alexandris:
> (enough?):
> -a- script-tc2787474.html#a2788062>
Michael, the thread started for bash but in the last posts (in it) python
stuff are demonstrated ( I recall so). Maybe I've posted directly a post where
no "python" is included? Hmm... let me see... ... ok, here it is:
1. http://www.mail-archive.com/grass-user@lists.osgeo.org/msg08280.html
2. http://www.mail-archive.com/grass-user@lists.osgeo.org/msg08288.html
Maybe they are outdated though (?).
Cheers, Nikos
On May 25, 2010, at 11:14 AM, Nikos Alexandris wrote:
Kim Besson:
example with that?
Location EPSG code?
Michael Barton:
Nikos Alexandris:
(enough?):
Cheers, Nikos
These work, but there is a better shortcut now from the GRASS Python library.
regiondict = grass.region()
will create a Python dictionary regiondict with values for extents and resolution. It's the same as creating a dictionary by parsing g.region -ugp
Michael
Nikos Alexandris:
>>> (enough?):
>>> n -a- script-tc2787474.html#a2788062>
library.
-ugp
Attached a simple python script with various ways to get "rows, cols" from the
"current" region.
Nikos
(attachments)
g.region.resolution.py (2.35 KB)
Thanks. Quite helpful.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On May 30, 2010, at 2:41 AM, Nikos Alexandris wrote:
Nikos Alexandris:
(enough?):
library.
-ugp
"current" region.
Nikos
<g.region.resolution.py>
