[GRASS-user] get message warning: unable to open font map in i.points such file
I use in university a cvs of GRASS 6.3 in debian.
The other day I got a problems with fonts in i.class and today the same using i.points.
There are no words on the buttons. onlay grey beams (Balken)
in Konsole I got the message
WARNING: unable to open font map ‘/usr/lib/grass/fonts/.hmp’: No such file
usr/lib/grass/fonts/.hmp contains:
GRASS:~$ ls -A /usr/lib/grass/fonts/
cyrilc.hmp greekc.hmp hersh.oc1 italicc.hmp romancs.hmp scriptc.hmp
gothgbt.hmp greekcs.hmp hersh.oc2 italiccs.hmp romand.hmp scripts.hmp
gothgrt.hmp greekp.hmp hersh.oc3 italict.hmp romans.hmp
gothitt.hmp greeks.hmp hersh.oc4 romanc.hmp romant.hmp
any idea what to change?
May I (as a user) do something or do I need a superuser?
Should we reinstall a newer cvs?
I there a mirror somewhere where we can find ready-to-use and up-to-date debian-packeges?
Thanks a lot
om shantih
Philipp
grass-user@lists.osgeo.org
WARNING: unable to open font map '/usr/lib/grass/fonts/.hmp': No such
file
scriptc.hmp
scripts.hmp
Apparently stroke fonts fail -- do things like d.legend or d.text print
text? 'unset GRASS_FONT' ?
self compilied? from original source or debian build?
It is a moving target, so usually you'd build it yourself, e.g.
  http://hamish.bowman.googlepages.com/debiangisfiles#compile
or get debian build rules from DebianGIS svn and run auto-build tools.
you might ask on the DebianGIS mailing list for better advice:
  http://wiki.debian.org/DebianGis
GRASS 6.2.3 (in unstable now, soon to be in testing and etch-backports)
is fine for most work and is well tested.
Currently at backports.org for Debian/Etch is version 6.2.1
  http://packages.debian.org/grass
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hi Hamish,
thank you for helping always and everybody in the way you do! Approvals!!!
d.legend or d.text don’t print text. I get the same message:
file
I’ll ask the superuser for answering the questions of compiling.
cheers
om shantih
Philipp
Hamish schrieb:
On 28/01/08 09:47, Philipp Steigenberger wrote:
Hi Hamish,
d.legend or d.text don't print text. I get the same message:
file
I'll ask the superuser for answering the questions of compiling.
Try running g.mkfontcap.
Moritz
I compiled the newest svn version (and also the 6.3.0RC4)
now all works well - no more problems with fonts
thank you
Philipp
Philipp Steigenberger schrieb
On Sat, 26 Jan 2008, Philipp Steigenberger wrote:
using i.points.
file
Sorry, meant to reply to this earlier. The usual solution for this is to run:
g.mkfontcap -o
to re-generate the font file.
Did you compile GRASS yourself? Were the compiled binaries moved to some other location in the filesystem without running "make install" - if so, the locations of the GRASS built-in fonts in the fontcap file would be wrong and it needs to be regenerated.
Paul
> file
run:
g.mkfontcap -o
Paul,
any chance to catch this warning and run g.mkfontcap -o automatically
if needed? That people move binaries around will happen regularly.
HI Paul,
the GRASS cvs I didn’t compile by myself. It was installed into the system. This days I couldn’t run g.mkfontcap, cause I hadn’t the permission.
Now that I have the superuser rights I already compiled GRASS svn - without makeinstall;
I’ll try the g.mkfontcap tomorrow with the cvs GRASS just to look if it will work.
cheers
Philipp
using i.points.
file
g.mkfontcap -o
Did you compile GRASS yourself? Were the compiled binaries moved to some other location in the filesystem without running “make install” - if so, the locations of the GRASS built-in fonts in the fontcap file would be wrong and it needs to be regenerated.
Paul
> > such file
Paul:
> is to run:
> g.mkfontcap -o
Markus:
hint added to the warning message in SVN.
Hamish
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
> > file
> run:
> g.mkfontcap -o
Paul,
There are potentially other things which can cause it, and we don't
want to overwrite the fontcap file if it has been edited by the user.
the GRASS cvs I didn't compile by myself. It was installed into the
system. This days I couldn't run g.mkfontcap, cause I hadn't the permission.
I'll try the g.mkfontcap tomorrow with the cvs GRASS just to look if it
will work.
If you don't have permission to modify etc/fontcap, you can use e.g.
"g.mkfontcap -s > ~/.gfontcap" to create a personal copy then use e.g.
"export GRASS_FONT_CAP=$HOME/.gfontcap" to make GRASS use that file
instead of the system copy.
will work.
Glynn,
In this way it works. But do I have to put this
into the .grass.bashrc, that don’t have to export it every time I open a new bash?
I opened a new bash and got there:
GRASS:~/gw$ echo $GRASS_FONT_CAP
GRASS:~/gw$
For my new GRASS svn it doesn’t matter, but for me its in general interesting to know how to work with export in such cases. Is there a file where the bash saves all the env-variables and how to influence it.
  • But probably this is off-topic…
cheers
om shantih
Philipp
Glynn,
into the .grass.bashrc, that don't have to export it every time I open a
new bash?
You only need to run g.mkfontcap once (or when you add new fonts), but
the "export" statement should go into ~/.grass.bashrc (or some other
shell startup script).
GRASS:~/gw$
For my new GRASS svn it doesn't matter, but for me its in general
interesting to know how to work with /export/ in such cases. Is there a
- But probably this is off-topic...
bash won't save environment variables, but it reads a number of files
at startup. The details are all in the bash(1) manpage, but some
subset of the following files will be read when an interactive shell
is started:
  /etc/profile
  ~/.bash_profile
  ~/.bash_login
  ~/.profile
  ~/.bashrc
Also, GRASS runs whatever is in ~/.grass.bashrc when starting the
session shell.
