I would like to identify the raster, in a r.series calculation for min (or max), where the result is coming from.
Is there a way to do so ?
Thank you
Frank
Thank you
Frank
Hi Frank
El sáb., 25 may. 2019 22:51, Frank David <frank.david@geophom.fr> escribió:
(or max), where the result is coming from.Is there a way to do so ?
max_raster, min_raster in r.series will give you the index of the raster map in the series containing either max or min values
Is that what you need?
Vero
Thank you
Frank
grass-user mailing list
grass-user@lists.osgeo.org
Hei Vero,
Use min_raster and max_for raster method in r.series…
Did you try that?
Stefan
From: grass-user grass-user-bounces@lists.osgeo.org on behalf of Veronica Andreo veroandreo@gmail.com
Sent: Sunday, May 26, 2019 6:02:47 AM
To: Frank David
Cc: grass-user
Subject: Re: [GRASS-user] get raster name in r.series min/max
Hi Frank
Vero
Thank you
Frank
On 26/05/2019 7:02, Veronica Andreo wrote:
Hi Frank
Vero
Hello Frank:
I used Vero’s suggestion in a script I was working on some months ago: I had a list of rasters, each represented a “station_id”. I used g.list to create the list of raster names, and fed that into r.series input= method=max_raster.
Then I used r.reclass to get back the station_id from the list index. I had a text file with matches between the index of the raster in the list, and it’s actual “station_id”. So r.reclass returned a raster with each pixel value being the station_id of the maximum raster in the list.
HTH
Thank you
Frank
https://lists.osgeo.org/mailman/listinfo/grass-user_______________________________________________ grass-user mailing list [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) [https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Hello,
Thank you very much Vero and Micha, It’s exactly what I was looking for ! That’s great !
Frank
Hi Frank
Vero
Hello Frank:
HTH
Thank you
Frank
Micha Silver
Ben Gurion Univ.
On Mon, May 27, 2019 at 4:22 PM Frank David <frank.david@geophom.fr> wrote:
Hello,
Thank you very much Vero and Micha, It's exactly what I was looking for ! That's great !
Please consider to write up a small example for the manual page and/or
the Wiki as it is of interest to many.
thanks
Hello,
I d’ont know how to do so, and my english is not very fluent… :-/
If someone write something about min/max_raster it could be useful to inform that it’s the output is the index of first min/max meet. Because the order of input raster make outpout different shape in case of equal min/max values in different input rasters and it’s a bit confusing at first
Frank
