[GRASS-user] Getting an error using r.mask in a GRASS shell script
All:
I have a GRASS bash shell script where all my GRASS commands (7.0.0beta3) execute just fine except for my call to set a MASK:
r.mask --overwrite input=$basin_mask@$MAPSET
I get this error…
File “/usr/local/grass-7.0.0beta3/scripts/r.mask”, line 71, in
import grass.script as grass
ImportError: No module named grass.script
I have never previously encountered this kind of thing calling r.mask in any of my GRASS scripts.
Any thoughts??
Thank you,
Tom
On 2015-01-26 23:57, Thomas Adams wrote:
All:
I get this error...
   File "/usr/local/grass-7.0.0beta3/scripts/r.mask", line 71, in <module>
There is no input parameter in G7:r.mask [1]. This info is however missing in [2], as I just noted. I am not sure of the behaviour of 7.0.0beta3, but my GRASS 7.1.svn comes up with:
ERROR: Sorry, <input> is not a valid parameter
Hermann
[1] http://grass.osgeo.org/grass70/manuals/r.mask.html
[2] http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Rastermodulechanges
Tom,
All:
I get this error...
Please consider to update to RC1, we have fixed all these errors.
Hermann
The lookup mechanism should now work fine (otherwise please report),
just beta3 didn't have it yet.
Markus,
Thank you for your help; I did try using RC1 (which I built shortly after it’s release) and got the same error – but I’ll try again. I can’t do that right now because I just kicked-off something else in a different GRASS LOCATION that’s taking a while to process. So, I won’t be able to try again until later.
Thank you,
Tom
On Tue, Jan 27, 2015 at 1:39 AM, Markus Neteler <neteler@osgeo.org> wrote:
Tom,
All:
I get this error…
ERROR: Sorry, is not a valid parameter
Hermann
just beta3 didn’t have it yet.
On Tue, Jan 27, 2015 at 8:31 AM, Thomas Adams <tea3rd@gmail.com> wrote:
Markus,
it's release) and got the same error -- but I'll try again. I can't do that
LOCATION that's taking a while to process. So, I won't be able to try again
until later.
Maybe a short but complete example would help us to test?
Anna
Thank you,
Tom
Tom,
>> All:
>> I get this error...
<module>
missing
but
> Hermann
> [2]
grass-user mailing list
grass-user@lists.osgeo.org
Anna,
I’m building RC1 on a different Linux box (where I had beta3); I’ll try again and if I get the same error, I’ll offer up an example — how would I do that? tar things up and put it on GoogleDrive?
Tom
On Tue, Jan 27, 2015 at 8:34 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Markus,
Anna
Thank you,
Tom
Tom,
All:
I get this error…
Hermann
On Tue, Jan 27, 2015 at 10:41 AM, Thomas Adams <tea3rd@gmail.com> wrote:
Anna,
I'm building RC1 on a different Linux box (where I had beta3); I'll try
again and if I get the same error, I'll offer up an example — how would I
I was thinking ideally about a short .sh file which can be attached. I
don't know how complicated that would be for you.
Tom
Markus,
after it's release) and got the same error -- but I'll try again. I can't
GRASS LOCATION that's taking a while to process. So, I won't be able to try
again until later.
Anna
Thank you,
Tom
wrote:
Tom,
>> All:
>> I get this error...
<module>
missing
7.0.0beta3, but
> Hermann
> [2]
Anna,
Below is my script. I am running on Ubuntu 10.10, GRASS 7 RC1 (built today). I have tried running my script two ways:
(1) external from GRASS, where I set the GRASS environment (the attached script) — this is how I have done almost all my GRASS scripting for years
(2) I remove the section where I set the GRASS environment and run from the GRASS prompt — this works perfectly fine!!! (I had not tried this previously when I first reported this problem)
Running as (1) is where I get the r.mask errors I have been seeing; I get the errors both when I simply remove any existing MASKs (r.mask -r) or where I attempt to set the MASK.
Cheers!
Tom
#!/bin/bash
Read the GRASS LOCATION and BASIN MASK as command line arguments
location=$1
basin_mask=$2
On Tue, Jan 27, 2015 at 8:45 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Anna,
I was thinking ideally about a short .sh file which can be attached. I don’t know how complicated that would be for you.
Tom
Markus,
Anna
Thank you,
Tom
Tom,
All:
I get this error…
Hermann
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
Can you please post again what are the errors. It is not clear from the
previous posts. Also, if you are posting script it is best to post a file,
not a screenshot, or just copy and paste the script to the email if it is
short enough.
Vaclav
Vaclav,
That was not a screen shot, just fg & bg colors of the text (I copied & pasted from my Mac term window — sorry for the embellishments). The errors I have been getting is this:
same result for RC1. My script is attached…
Tom
(attachments)
dem2rdhm_alpha (3.16 KB)
On Tue, Jan 27, 2015 at 12:57 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Can you please post again what are the errors. It is not clear from the previous posts. Also, if you are posting script it is best to post a file, not a screenshot, or just copy and paste the script to the email if it is short enough.
Vaclav
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
On Tue, Jan 27, 2015 at 3:04 PM, Thomas Adams <tea3rd@gmail.com> wrote:
Vaclav,
I see it now. I was confused because it looks really bad at my end.
"ImportError: No module named grass.script" means that Python does not see
package (grass.script or also grass). You miss the PYTHONPATH variable
which says where Python packages are:
export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
See the following in case you are missing some other variable which would
be important for you (probably none now):
http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Bash_examples_.28GNU.2FLinux.29
If you would have a lot of problems with setting the environment, use
GRASS_BATCH_JOB variable with the grass command (see grass70 --help).
I hope this helps,
Vaclav
Tom
short enough.
Vaclav
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
Vaclav,
Fantastic; that did the trick! I figured the issue had to be something like that, but I just had not been able to find it and, until now, this had not been an issue.
Thank you very much…
Best regards,
Tom
Vaclav,
“ImportError: No module named grass.script” means that Python does not see package (grass.script or also grass). You miss the PYTHONPATH variable which says where Python packages are:
export PYTHONPATH=“$GISBASE/etc/python:$PYTHONPATH”
See the following in case you are missing some other variable which would be important for you (probably none now):
If you would have a lot of problems with setting the environment, use GRASS_BATCH_JOB variable with the grass command (see grass70 --help).
I hope this helps,
Vaclav
Tom
Vaclav
