What would be the most efficient way of getting the coordinates for each input raster cell? I'm using this in a Python script that creates a separate cost surface (using r.cost) for each cell (yes, that is computationally intensive thing indeed, but that's not a problem itself). I've been using a simple function I made that creates a list of coordinates via iteration starting from the region corner and using cellsize as a step. But this does not check for null-values in the raster (which I would like to exclude) and I'm also not very sure how it would play out with some coordinate systems. One way to solve the null-value issue would be to impose an r.what check, but this does not seem to be very elegant way to do it.
Any suggestions? I'm more or less comfortable with using ctypes, so that route would perhaps be the best in terms of performance.
What would be the most efficient way of getting the coordinates for each input raster cell? I’m using this in a Python script that creates a separate cost surface (using r.cost) for each cell (yes, that is computationally intensive thing indeed, but that’s not a problem itself). I’ve been using a simple function I made that creates a list of coordinates via iteration starting from the region corner and using cellsize as a step. But this does not check for null-values in the raster (which I would like to exclude) and I’m also not very sure how it would play out with some coordinate systems. One way to solve the null-value issue would be to impose an r.what check, but this does not seem to be very elegant way to do it.
Any suggestions? I’m more or less comfortable with using ctypes, so that route would perhaps be the best in terms of performance.
Any suggestions?
