[GRASS-user] Getting vectors from postscript files
I have a large and layered PDF map which I'd like to get into Grass-GIS, preferably without tracing the vectors by hand - there are hundreds!
I've been looking at various ways to extract the vectors - in particular using tools like pdf2ps, pstoedit and fig2dev - to try and get the data into some kind of usable format. However, the best I can seem to do is to get an SVG (scalable vector graphics) file that contains the relevant vectors.
Is there a tool that will let me import vectors from either PDF, PS, or SVG into Grass-GIS?
Richard Chirgwin
vectors.
SVG into Grass-GIS?
CorelDraw can convert import SVG and export DXF, which can be read
with v.in.ogr.
Inkscape is supposed to be getting DXF export, but I don't know the
current state of progress.
with v.in.ogr.
Thanks Glynn - Since I'm a Linux user, I'll have to try and wrangle Inkscape ... Its main problem at the moment is that the SVG is too big for it, so I need to figure out some way to slice up the image beforehand.
Richard
On Tue, Aug 19, 2008 at 11:44 PM, Richard Chirgwin
into Grass-GIS?
In the past I had some success with pstoedit:
http://www.pstoedit.net/pstoedit/
pstoedit -f dxf mapfile.eps mapfile.dxf
Fails for you? Possibly (don't remember), I used ps2eps (written by
Roland Bless [1])
to generate EPS from PS first.
[1] http://www.tm.uka.de/~bless/ps2eps
into Grass-GIS?
Roland Bless [1])
Markus - Thanks! Works brilliantly ... now I just have to work out how to just get the vectors I want, and life is going to be good ...
Richard Chirgwin
